72 Challenger PITMAN ARM Questions??????? #111123
08/27/08 12:22 PM
08/27/08 12:22 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
1. Where can you buy a good one that doesn't cost 150.00.
2. Does it matter what size engine was originally in the car as opposed to putting a bigger engine in?? original was 318, had a 340 when I bought it and I am going to put a 440 in it.
Are there different arms for diff. engines??? which one will I need?? Etc, Etc.
Thanks,
Tony
aholtzapple@cinci.rr.com
Re: 72 Challenger PITMAN ARM Questions??????? [Re: holtzdog55] #111124
08/27/08 12:28 PM
08/27/08 12:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Thanks,
Tony
If it's a small output sector shaft you are stuck. You could get a new steering box then you can get the 73-74 arm thats alot cheaper , the new box will cost more than the $150 steering arm .
If your box has alot of miles just buy a new box and put that $150 towards new good parts .
