How to Install/Adjust Trunk Springs - The Right Way? #1111180
11/11/11 02:12 AM
11/11/11 02:12 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I know there is a way to adjust trunk hinge springs without the great danger and paint scratching that comes with trying to move the spring end from one notch to another, but I am not sure about the technique.
Anyone know the correct way to install/adjust these things? Thanks.
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: lahatte] #1111181
11/11/11 12:26 PM
11/11/11 12:26 PM
New York, Chautauqua county
mightycuda Offline
mightycuda  Offline
Bump this back to the top. Inquiring minds want to know.
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: lahatte] #1111182
11/11/11 02:55 PM
11/11/11 02:55 PM
GMP440 Offline
GMP440  Offline
Yes, they can be adjusted. I did this on my 68' Dodge Coronet. Keep in mind the direction of more tension is towards the rear of the car and less tension is towards the front of the car. I tied a rope to the loop part of the rod that goes in the hole. I would pull the rope out and back until the rod goes to the next hole. Yes, it does scratch the paint, but when you are done just scuff the scratches and shoot a little paint to touch up that area.
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: GMP440] #1111183
11/11/11 03:26 PM
11/11/11 03:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Sounds good (need to do this to the GTX) but isn't there a way to NOT scratch the paint? Maybe a paint stirrer or something taped to the area between the slots?
MikeR
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: A12] #1111184
11/11/11 03:28 PM
11/11/11 03:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
MikeR
By the design of them I think there is very little chance of not scratching the paint ....
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: JohnRR] #1111185
11/11/11 05:08 PM
11/11/11 05:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
MikeR
seeing that you need to do both sides, I'm thinking about using one of my many motorcycle "ratcheting" tie down straps between both springs and pulling them both out with the ratchet at the same time and then moving the trunk lid and releasing the tie down strap at just the right point I'll let you know
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: A12] #1111186
11/11/11 05:12 PM
11/11/11 05:12 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
this kind of tie down, what do you think?
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: A12] #1111187
11/11/11 05:25 PM
11/11/11 05:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'm thinking it just might work, even looped with a place to put the plastic covered tie down hooks
MikeR
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: A12] #1111188
11/11/11 06:14 PM
11/11/11 06:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
At least put some painters tape on the paint for a little protection.
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: burdar] #1111189
11/11/11 09:17 PM
11/11/11 09:17 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
another way would be to get an all-thread rod, turnbuckle and "hook" shape the all-thread on each end (cover with rubber hose) with the turnbuckle in the center. I think they have hooks that can be threaded on also as another option.
Re: How to Install/Adjust Trunk Springs - The Right Way? [Re: A12] #1111190
11/12/11 01:30 AM
11/12/11 01:30 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I seem to recall that there is an easy way to install these. I might be wrong, but what I recall is that the locking tip that goes in the slot is put in first, then the upper part of the rod is pulled into its location. I haven't tried this. I was waiting for some posts here.
