did one of these about 10 years ago. In retrospect, i REALLY REALLY wish i had access to an air hammer.
I could have done a MUCH neater job of selectively dimpling several areas of the tunnel. I ended up grinding an 1/8" ( or so ) off the housing extension to gain a little more room where the T bar crossmember goes over the unit.
You want to get the tail of the housing as high as you can. It will help with drivetain angles and ground to exhaust clearance.
It is an fairly easy install.
Sometimes I wish I still had it.
