Fiberglass Bolt-on Cuda Trunk Lid??? #111038
08/27/08 09:21 AM
08/27/08 09:21 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
hey guys
wanted to get a fiberglass bolt on trunk lid for my Cuda and not sure which to get?
looking at Glasstek or AAR fiberglass
anyone else use them? how is quality and is the latch area pretty sturdy?
just wanting to know if they are worth the $300-$350 bucks!
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111039
08/27/08 10:12 AM
08/27/08 10:12 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I had a bolt on lid for my 69 Barracuda from AAR. Nice piece, plenty sturdy.
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: AdamR] #111040
08/27/08 11:00 AM
08/27/08 11:00 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have parts from Glasstek and AAR for my Duster. Quality is top notch on both.
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111041
08/27/08 11:02 AM
08/27/08 11:02 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I have dealt strictly with AAR , and have always gotten a quality product.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111042
08/27/08 12:41 PM
08/27/08 12:41 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Here is a pic of the AAR fiberglass bolt-on trunklid top. The pic of the bottom I took turned out too dark to be useful !
A couple caveats :
1. Adjustment is made via the trunklatch. Is your latch support in good shape ? AMD sells new ones if not.
2. Depending on year, you may have problems reaching the bolts when bolting the inner "steel inserts" My car is a '72, and I believe the other years have a slightly different config. AAR just cut out a little recess, so I could reach my ham-fists back under there.
3. Be prepared to do a lot of "futzing" to make it fit right. Recommend a new trunk weatherstrip. You'll need to read the instructions in your FSM body manual - they sound a bit odd, but the instructions work when followed to a "T" - esp the overlap part.
Good luck.
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111043
08/27/08 07:32 PM
08/27/08 07:32 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
anybody have an actual Glasstek 70-74 cuda trunk lid?
any feedback on quality?
wanted to save $50 bucks
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111044
09/16/08 10:36 PM
09/16/08 10:36 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
here is my Glasstek trunk lid I got today!
quality is really nice and paid $339 shipped to my door
I had to reuse all the mounting stuff from the old trunk lid except for two bolts
here are pics with my fiberglass AAR spoiler I got from Year One
came out pretty good fit just got to tweak it some more to get the gaps perfect
metal trunk lid weighs 21 lbs
fiberglass trunk lid & spoiler 15 lbs
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111045
09/17/08 10:25 AM
09/17/08 10:25 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Hey, that looks good!!!
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: 70blackfish] #111046
09/17/08 05:11 PM
09/17/08 05:11 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I have a fiberglass bolt on and I was disappointed I had to do the cutting on the lid. I also didn't want to have to position the nut strip inside the lid because the stock lid uses ohillips screws to lock the nut plate and I wasn't sure I could get it all lined up. Did you have a problem?
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111047
09/17/08 06:42 PM
09/17/08 06:42 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
That lid looks good. Fantastic install job.
Yes, to install my lid, I had to have AAR cutout some of the underside, so I could get the nut strips bolted up . Doesnt look "stock" now, but I really could give a flying flip - this is a "worthless" '72 ( apologies to UNLAWFL for stealing one of his pet phrases)
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: Cudajon] #111048
09/17/08 11:46 PM
09/17/08 11:46 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
nope no problem at all
as you can see the little blue philips screw is there. the Glasstek lid is almost the exact copy of my metal trunk lid!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Fiberglass Bolt-on Cuda Trunk Lid??? [Re: RylisPro] #111049
09/18/08 08:47 PM
09/18/08 08:47 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Nice piece
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
