rcommended KYB or Bilstein upgraded handling fr shocks? #1110260
11/09/11 05:58 PM
11/09/11 05:58 PM
Kent, WA
triple_green Offline OP
Kent, WA
What is the manuf and model upgraded handling shocks that you guys recommend? 68 Charger. I have Edelbrock IAS's in the rear and they are OK, not great.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: triple_green] #1110261
11/09/11 06:00 PM
11/09/11 06:00 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Don't do KYB, Bilsteins are great.
=Daty
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: Daty Rogers] #1110262
11/09/11 06:18 PM
11/09/11 06:18 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
=Daty
had KYB gas-a-justs on my M body...they were harsh. I'd probably go bilsteins if edelbrock doesn't make a matching front shock. I replaced the KYB's with monroe sensa-tracs, handle as good, and ride MUCH better.
2017 Grand Cherokee Overland
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: triple_green] #1110263
11/09/11 07:23 PM
11/09/11 07:23 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I have KYB on my AHB M body, with alot of poly bushings too, and the ride is harsh. Next time I am going to try something else.
Facts are stubborn things.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: larrymopar360] #1110264
11/09/11 07:28 PM
11/09/11 07:28 PM
Prescott Az
73 SSP Offline
73 SSP  Offline
Prescott Az
That is how the 72 roadrunner I had was set up felt like was in a washboard all the time.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: 73 SSP] #1110265
11/09/11 07:52 PM
11/09/11 07:52 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
As others have said, there is no comparison between KYB's and Bilsteins. Bilsteins are far better
Steve
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: triple_green] #1110266
11/09/11 09:23 PM
11/09/11 09:23 PM
AndyF Offline
AndyF  Offline
Pay the extra money for the Bilstein shocks. Firm Feel over in Vancouver can take care of you. They'll know what shocks will work best for your combo.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: AndyF] #1110267
11/09/11 11:26 PM
11/09/11 11:26 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
I have eddy ias on the front of my 69 charger it rides like a tank .putting monroe back on in the spring .I will only put adjustable shocks on next time . The old you get what u pay for .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: sparcy] #1110268
11/10/11 11:48 AM
11/10/11 11:48 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I'm a fan of regular old Monroe-matics. If the rest of your suspension is in good shape, that is all you should need for any regular hot-dogging. You should never use shocks to compensate for lousy spring rate, but often that is what Joe Carguy does.
Not only did I find KYBs to be excessively harsh, they didn't let the suspension do it's job. As a result, I was a lot less comfortable with the car. For the same reason that people want manual steering for increased road feel, or manual brakes to push it to the ragged edge, a little body roll here or nose dive there is a good thing; all that feedback lets you push it a bit farther, and keeps you from overdoing it if you're paying attention. Not to mention it's more fun - most people expect a big block monster to rear up and plow into the corners, and it's quite a show when it does.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: Montclaire] #1110269
11/10/11 01:00 PM
11/10/11 01:00 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I must be in the minority. I always liked the KYB's for handeling. I admit they ride smoother on coil spring GM cars but I found then acceptable on torsion bar B bodies.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: finadk] #1110270
11/10/11 01:21 PM
11/10/11 01:21 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Honestly it depends on the road surface. The KYBs seem to be progressively valved, so that they pump up a little more after repeated motion. If you live in an area such as the rust belt (and I see you're in NJ, so I can't account for you lol) where roads are patched and re-patched, it doesn't take long for bump-bump-bump to become bam-Bam-BAM! Use them on a smooth surface, such as a road coarse, and your results will vary greatly. But then again you'd probably be running a reservoir shock or at least a better unit, and it would likely be a dedicated track car.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: Montclaire] #1110271
11/10/11 07:35 PM
11/10/11 07:35 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Hotchkis/Bilsteins made a noticable improvement on the Coronet.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: DennisH ] #1110272
11/10/11 09:35 PM
11/10/11 09:35 PM
Kent, WA
Kent, WA
Dennis how much of the Hotchkis stuff did you uby?
Thanks!
mark
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: Montclaire] #1110273
11/11/11 01:02 AM
11/11/11 01:02 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I tried several brands of shocks on my Volare RR. I had the car for 31 years, then finally sold it.
The KYB's that I installed 20 plus years ago made a drastic improvement over any available brand.
People would often comment on how good my car rode and handled.
I'm going to try them again on my '74 Challenger that will have some Hotchkis components as well.
They have to be a hell of a lot better than the drag shocks that were on the car. If not, they were a bargain price compared to the high end shocks, and can be replaced when I have $400 for shocks.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: racealittle] #1110274
11/11/11 02:32 PM
11/11/11 02:32 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Well the F body is a different animal, having both the iso-K bushings and the tranverse torsion bars...
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: racealittle] #1110275
11/11/11 03:01 PM
11/11/11 03:01 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
What were the specific brands models of shocks did you run/try on your Volare RR??
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: autoxcuda] #1110276
11/11/11 07:49 PM
11/11/11 07:49 PM
racealittle Offline
racealittle  Offline
30 plus years ago there wasn't a choice like today.
I got the car new with the factory RR/Superpack options.
After a few years I tried the best Monroe available, then the best Sears Steady Riders. At this point I had already flatten 3 out of 4 header pipes on my high dollar headers (I think they were a set of Dougs). Going through intersections at high speed made sparks on the driver side header.
The frame was tied on the car. That made a difference you could feel,
I bought the complete S-21 cop handling package (less shocks) from the dealer. This was about year four of ownership. This made a big improvement on the car.
Year 5, I installed a 440/727 from a '68 RR with RR exhaust manifolds and custom bent exhaust with '81 Imperial tailpipes on the passenger side. The bounce in the intersection was back with the extra weight on the nose. That is when I tried the KYB shocks. The combination worked well from that point on. 25 years with the KYB's.
I put 2" TTI's, 3" self made x pipe with cutouts after the X on the car when the eddy heads went on the 440. The heads, headers, and rpm intake made about a 100 plus hp difference, which I verified with timeslips and 3 pulls on an old mustang chassis dyno.
That car was a sweet riding/handling street car. However it was a year round driven car, that was parked in the weather. Certain kinds of rot are just too hard to fix for me, and didn't justify the $$ involved to repair.
That's when I bought an e body to spend $$ on, because anything can be bought to repair those cars. E body cars can be decent handlers. Hotchkis, Firm Feel, XV, etc, etc.
Sold my FED, and other racing related interests, to build and own just one ride that can do it all. By that I mean race a little, drive it a lot; as a daily driver if I wish, or add one of my higher compression 440's, a converter, and a gear for drags, or perhaps try my hand at a Hotchkis sponsored event if I can time things right.
Re: rcommended KYB or Bilstein upgraded handling fr shocks? [Re: triple_green] #1110277
11/11/11 08:53 PM
11/11/11 08:53 PM
DennisH Offline
Vacation
DennisH  Offline
Vacation
Thanks!
mark
Just the Bilsteins for now. All 4. Budget. They make a dramatic improvement - on their own. Washboard streets in town and triple-digit heaving two lanes in the Desert too. (I'm told).
