Re: 8 3/4 back bracing
[Re: hemiluver]
#111027
08/27/08 04:12 PM
08/27/08 04:12 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Mine has load bolt provisions through the back brace.
CrAzYMoPaRGuY
[Re: jcc]
#111032
08/27/08 11:52 PM
08/27/08 11:52 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
What exactly is the "bolt-load" for?Sorry for the ignorance but I see it al the time but I don't understand. Is something getting drilled thru the rear end? Please explain in detail(dumb it down for me) I have been thinking about a backbrace myself for a 489 in a b-body with manual trans. Thanks if anyone can help-John
I believe the main purpose is to preload the stock caps that are thought to be under strenght for the task, by transfering some of their flex and therefore their load to the axle housing thru the bolts that are loaded to the center of the rear of the caps. However I am not sure any of that is necessary when using the much stronger say MW steel billet caps and bolts/studs.
This topic gets a lot more airtime in the race section
You need them even with the billet caps because I think more than one person has split a billet cap .
This is another one of those threads where the OP is FISHING for the answer he WANTS to hear, but hey it's your money so do what YOU want , you do not need the blessing of anyone else on how you choose to spend YOUR cash , I know i don't go asking anyone else how I should spend my money once I have my mind set.
[Re: jcastle1]
#111034
08/28/08 01:32 AM
08/28/08 01:32 AM
CrAzYMoPaRGuY
Canada
The housing is drilled, the back brace is drilled, and a threaded tube is welded in, both inside to the housing and outside to the brace.
CrAzYMoPaRGuY
[Re: hemiluver]
#111036
08/28/08 01:33 PM
08/28/08 01:33 PM
CrAzYMoPaRGuY
Canada
Welding the backbrace will for sure need to be done in a jig IMO.
CrAzYMoPaRGuY
