? on upper control arms #1110246
11/09/11 04:45 PM
11/09/11 04:45 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Is there a difference in bushing size if the car has a big block vs a small block? Car is mine in the sig. or is there a difference between 73 74 B bodies
I am trying to understand how the bushings could be to small
Re: ? on upper control arms [Re: 73 SSP] #1110247
11/09/11 05:04 PM
11/09/11 05:04 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The suspension changed on the 73 and up b body cars, but the bushings would be the same between big block, and small block.
The car doesn't care what size engine is in it.
Now, bushings for 62-72 b bodies, are the same, but lots different from 73 up cars.
Do you have bushings from 62-72 cars? and then there is your problem.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: ? on upper control arms [Re: hemi71x] #1110248
11/09/11 05:21 PM
11/09/11 05:21 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
the shop that has the car just told me the bushings they got match the ones from the broken control arm but are too small for the used one I ordered from desert valley auto parts in Phx.
Re: ? on upper control arms [Re: 73 SSP] #1110249
11/09/11 05:53 PM
11/09/11 05:53 PM
hemi71x Offline
hemi71x  Offline
If the used control arm doesn't match up to the one that came off your car, then the replaement one is obviously wrong.
Re: ? on upper control arms [Re: hemi71x] #1110250
11/09/11 05:58 PM
11/09/11 05:58 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
thanks hemi71x that's what I was thinking too
Re: ? on upper control arms [Re: hemi71x] #1110251
11/09/11 06:01 PM
11/09/11 06:01 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
These are 73 Charger control arms.
Re: ? on upper control arms [Re: hemi71x] #1110252
11/09/11 07:17 PM
11/09/11 07:17 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
It sure is the wrong one here are the specs old one bushing OD 1.423" replacement A arm bushing OD 1.18"
Re: ? on upper control arms [Re: 73 SSP] #1110253
11/11/11 10:48 AM
11/11/11 10:48 AM
USA
ramairthree Offline
ramairthree  Offline
USA
I have the "curse of the 73/74 B body" as well
Many places will try to sell you parts that fit '72-earlier B-Body,
and 73/74 A-Body parts because they think they match or a book says they match.
And while much stuff does interchange like that, you will find a ton of stuff that fits an up to 72 Body, and all the 70-74 A bodies, but not a 73/74 B Body.
I believe your UCA and bushings is an example of that.
