Pitman arm grease boot? #1110116
11/09/11 11:12 AM
11/09/11 11:12 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
I have the grease boot on my Pitman arm which is split and needs to be replaced. The arm itself is in great shape so i don'y want to shell out the money to replace. I have not seen any specific boot sold alone for this part. Does this use the same grease boot as the tie rod ends? I can find just the boots for those but not the Pitman arm.
Car is a 73 Charger P/S with stock replacement tie rod ends/Pitman arm. Thanks guys!!
Re: Pitman arm grease boot? [Re: cjskotni] #1110117
11/09/11 09:44 PM
11/09/11 09:44 PM
michigan
black64 Offline
black64  Offline
michigan
Try your local auto parts store they sometime have boots in the help section racks. Or if you have a good front end repair shop they usually have boots on hand they might sell you.
Re: Pitman arm grease boot? [Re: black64] #1110118
11/09/11 10:37 PM
11/09/11 10:37 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
http://www.energysuspensionparts.com/Energy-Suspension-Universal-Dust-Boots.asp
Look here.
Energy Suspension has universal boots, if you can't get what you want at a local parts store,
RF-4C Phantom 69-370 Zweibrucken, Germany
