Build me a budget Dana 60
#1109270
11/08/11 09:54 AM
11/08/11 09:54 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
I have a Dana 60 from a 79 Ford truck with factory 4.10 gears and clutch type posi. I want to build a budget Dana to fit my 70 Cuda using the stock 4.10 gears and posi. Please recommend the best bang for the buck to make this work using my original 11x3 rear drums. Who has the best deal on Mopar housing ends and axles? Also, any other thoughts are welcome. Thanks.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Build me a budget Dana 60
[Re: JohnRR]
#1109272
11/08/11 01:25 PM
11/08/11 01:25 PM
dogdays
[Re: dogdays]
#1109274
11/08/11 01:39 PM
11/08/11 01:39 PM
Triple Threat
Renton Washington
Problem is that the posi unit you have probably takes 18 or 23 spline axles or something like that. So you either need goofy custom axles or to convert/rebuild it to accept the standard 35 spline stuff.
Cass aka Dr Diff can tell you all of this, and help you weigh your options. Just give him a call he's super easy to talk to.
[Re: Triple Threat]
#1109275
11/08/11 02:06 PM
11/08/11 02:06 PM
Posts: 1,169 MI
68shifter
MI
Cass(DocDiff) is your best source for info and parts. Housing ends $75 or so Setup kit. $120 or so Axles c/ bearings $300 (35 spline) MW jig. $500 or shops will shorten for $250 or so. Watch that gear set also, some truck stuff has odd course spline pinions making yoke availability challenging. To bad yah didn't live closer you could use my jig. Best of luck
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: 68shifter]
#1109276
11/08/11 02:28 PM
11/08/11 02:28 PM
Posts: 694 Michigan
Super Scamp
www.doctordiff.com That will work as said in the upper post. 1.Truck Housing Free or 100 bucks 2. Cut and straighten 100.00 3.Ends welded MW ends 65.00each 4. brackets welded on Dana 50.00 5.Ring&pinion 400.00 or more spool 250.00 6.Setup and installed 150.00 7. MW axles or others 400.00 35 spline 8. Dana cover 165.00 9 Fluid 10.00 9.5 Axle studs 5/8 swap meet new 50.00 10 This is doing the running around and wheeling and dealing with people that can do this type of work. No Brakes or lines This is what it looked like after all was done... Good Luck..
Just One Man's Opinion
Mopar Mafia Racing
[Re: Cab_Burge]
#1109278
11/08/11 02:52 PM
11/08/11 02:52 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
FWIW...I have 2 Dana 60s out of mid 70s trucks (one ford, one dodge) and both have 23 spline axles.
[Re: astjp2]
#1109281
11/08/11 04:06 PM
11/08/11 04:06 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I just priced everything to do a truck Dana 60 myself. This is what I found from Dr. Diff (cass) Dana 60 spool $125 35 spline axles with bearings and 3" studs $300 pair most lengths gears 3.54, 3.73, 4.10 or 4.56 $195 pair install kit $125 add ring gear bolts $15 set axle flanges for the end $70 pair, plain $145 pair deluxe kit with inner seals, studs and nuts and spring perches $15 pair 1350 forged steel U-bolt yoke $70 Comes to $1060
67' charger 499 RB
10.57 at 127
[Re: BLONDE BARRACUDA]
#1109283
11/08/11 05:10 PM
11/08/11 05:10 PM
dragram440
bigfork mn
The 60 is heavier then hell. Right now it has huge drums and full floating axles. Took everything my brother and I had to carry it across the guys drive way I bought it from and into the back of the truck.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1109284
11/08/11 05:12 PM
11/08/11 05:12 PM
an8sec70cuda
Once you get rid of all the factory truck brake setup and put a spool in it gets MUCH lighter.
[Re: an8sec70cuda]
#1109285
11/08/11 05:44 PM
11/08/11 05:44 PM
dragram440
bigfork mn
I have just been to busy to get it in the shop and pull it all apart and plasma cut all the old brackets and crap off it. Im sure its gonna lighten up alot.
67' charger 499 RB
10.57 at 127
