Build me a budget Dana 60 #1109270
11/08/11 09:54 AM
11/08/11 09:54 AM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
I have a Dana 60 from a 79 Ford truck with factory 4.10 gears and clutch type posi. I want to build a budget Dana to fit my 70 Cuda using the stock 4.10 gears and posi. Please recommend the best bang for the buck to make this work using my original 11x3 rear drums. Who has the best deal on Mopar housing ends and axles? Also, any other thoughts are welcome. Thanks.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Build me a budget Dana 60 [Re: 11secaarcuda] #1109271
11/08/11 10:26 AM
11/08/11 10:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does it have provision for the pinion snubber? Do you need the pinion snubber? Do you have a welder ? Can you weld ? Do you have the jig to change the axle ends ? What is your budget ?
Re: Build me a budget Dana 60 [Re: JohnRR] #1109272
11/08/11 01:25 PM
11/08/11 01:25 PM
dogdays Offline
dogdays  Offline
Re: Build me a budget Dana 60 [Re: JohnRR] #1109273
11/08/11 01:36 PM
11/08/11 01:36 PM
OHIO
THE GLASS MAN Offline
OHIO
Gotta keep those axles straight. Need a jig.
Re: Build me a budget Dana 60 [Re: dogdays] #1109274
11/08/11 01:39 PM
11/08/11 01:39 PM
Renton Washington
Triple Threat Offline
Renton Washington
Problem is that the posi unit you have probably takes 18 or 23 spline axles or something like that. So you either need goofy custom axles or to convert/rebuild it to accept the standard 35 spline stuff.
Cass aka Dr Diff can tell you all of this, and help you weigh your options. Just give him a call he's super easy to talk to.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Build me a budget Dana 60 [Re: Triple Threat] #1109275
11/08/11 02:06 PM
11/08/11 02:06 PM
MI
68shifter Offline
68shifter  Offline
MI
Cass(DocDiff) is your best source for info and parts.
Housing ends $75 or so
Setup kit. $120 or so
Axles c/ bearings $300 (35 spline)
MW jig. $500 or shops will shorten for $250 or so.
Watch that gear set also, some truck stuff has odd course spline pinions making yoke availability challenging. To bad yah didn't live closer you could use my jig.
Best of luck
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Build me a budget Dana 60 [Re: 68shifter] #1109276
11/08/11 02:28 PM
11/08/11 02:28 PM
Super Scamp Offline
Super Scamp  Offline
www.doctordiff.com
That will work as said in the upper post.
1.Truck Housing Free or 100 bucks
2. Cut and straighten 100.00
3.Ends welded MW ends 65.00each
4. brackets welded on Dana 50.00
5.Ring&pinion 400.00 or more spool 250.00
6.Setup and installed 150.00
7. MW axles or others 400.00 35 spline
8. Dana cover 165.00
9 Fluid 10.00
9.5 Axle studs 5/8 swap meet new 50.00
10 This is doing the running around and wheeling and dealing with people that can do this type of work. No Brakes or lines This is what it looked like after all was done...
Good Luck..
Just One Man's Opinion Mopar Mafia Racing
Re: Build me a budget Dana 60 [Re: 11secaarcuda] #1109277
11/08/11 02:48 PM
11/08/11 02:48 PM
Pull one of the stock axles and count the splines, they probally are either 30 or 35 splines, the 18 and 23 splines where pre 1970 Either way you can have new car type axles made for your rear end just like what came in the original cars Are you going to have it shorten to the stock width or narrower like a 1970 and earlier B body? That width might fit better Dana made those rear ends for all three car makers so they have parts to make any axle spline fit in the posi and open carriers I have swapped the spider and side gears from 23 spline to 30 and 35 splinnes to use the bigger axles in cars and trucks
Re: Build me a budget Dana 60 [Re: Cab_Burge] #1109278
11/08/11 02:52 PM
11/08/11 02:52 PM
an8sec70cuda Offline
FWIW...I have 2 Dana 60s out of mid 70s trucks (one ford, one dodge) and both have 23 spline axles.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Build me a budget Dana 60 [Re: an8sec70cuda] #1109279
11/08/11 03:10 PM
11/08/11 03:10 PM
That supric=ses me I have a Dana 60 out of a mid 1970 Dodge Ram Van, I'm going to pull one of those axles now and see what splines are in it I'm planning on using it(converting it) in a street car with one of the clutch type posi(one 23 and one 35 spline) that I already have
Re: Build me a budget Dana 60 [Re: Cab_Burge] #1109280
11/08/11 03:34 PM
11/08/11 03:34 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Dutchman wants 380 to hot tank, narrow, and install billet ends including shipping. Ford ran 30 or 35 spline in their larger trucks. I am installing the Dana 70 gears in the 60 housing. It only costs 150.00 more and gives a 30% increase in strength. If you want disc brakes, have dutchman install the billet big ford ends and then get a disc brake setup from teraflex, the kit is 189 for the backing plates and you can use explorer or grande cherokee rotors and calipers from a salvage yard. I will have around 1200 in my hybrid axle when done. 3.55 gears and 35 spline power lock. Tim
Re: Build me a budget Dana 60 [Re: astjp2] #1109281
11/08/11 04:06 PM
11/08/11 04:06 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I just priced everything to do a truck Dana 60 myself. This is what I found from Dr. Diff (cass)
Dana 60 spool $125
35 spline axles with bearings and 3" studs $300 pair most lengths
gears 3.54, 3.73, 4.10 or 4.56 $195 pair
install kit $125
add ring gear bolts $15 set
axle flanges for the end $70 pair, plain
$145 pair deluxe kit with inner seals, studs and nuts
and spring perches $15 pair
1350 forged steel U-bolt yoke $70
Comes to $1060
67' charger 499 RB 10.57 at 127
Re: Build me a budget Dana 60 [Re: Super Scamp] #1109282
11/08/11 05:08 PM
11/08/11 05:08 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
looks good did you ever weigh it?
Re: Build me a budget Dana 60 [Re: BLONDE BARRACUDA] #1109283
11/08/11 05:10 PM
11/08/11 05:10 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
The 60 is heavier then hell. Right now it has huge drums and full floating axles. Took everything my brother and I had to carry it across the guys drive way I bought it from and into the back of the truck.
Re: Build me a budget Dana 60 [Re: dragram440] #1109284
11/08/11 05:12 PM
11/08/11 05:12 PM
Once you get rid of all the factory truck brake setup and put a spool in it gets MUCH lighter.
CHIP
Re: Build me a budget Dana 60 [Re: an8sec70cuda] #1109285
11/08/11 05:44 PM
11/08/11 05:44 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have just been to busy to get it in the shop and pull it all apart and plasma cut all the old brackets and crap off it. Im sure its gonna lighten up alot.
Re: Build me a budget Dana 60 [Re: dragram440] #1109286
11/08/11 05:56 PM
11/08/11 05:56 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Bare housing weights 68 lbs.
Re: Build me a budget Dana 60 [Re: astjp2] #1109287
11/08/11 09:40 PM
11/08/11 09:40 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I bought a complete dana 60 at the wrecking yard for $75. I made a jig to narrow up a dana and install 8-3/4 ends. Cost $0 ( I work cheap for myself). E-bay 4.56 gear set, E-bay spool, E-bay bearing, seal, and shim kit. Cost ~$335. Moser custom axles. Cost $440. Total $850 Dave
Re: Build me a budget Dana 60 [Re: quickd100] #1109288
11/08/11 11:19 PM
11/08/11 11:19 PM
grande prairie , ab , canada
68notch Offline
68notch  Offline
I bought a complete dana 60 at the wrecking yard for $75. I made a jig to narrow up a dana and install 8-3/4 ends. Cost $0 ( I work cheap for myself). E-bay 4.56 gear set, E-bay spool, E-bay bearing, seal, and shim kit. Cost ~$335. Moser custom axles. Cost $440. Total $850 Dave [/quote
can i ask how you made youre jig
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: Build me a budget Dana 60 [Re: 68notch] #1109289
11/08/11 11:29 PM
11/08/11 11:29 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Machined out 2, 1" steel plates the same diameter as the carrier bearings and 2, 1" steel plates the same diameter as the axle bearings. Drilled them out to 1-1/4". Used a piece of 1-1/4" steel shafting to slip through them and line everything up. Dave
Re: Build me a budget Dana 60 [Re: quickd100] #1109290
11/09/11 11:32 PM
11/09/11 11:32 PM
68notch Offline
68notch  Offline
thanks
