date code on master cylinder #1109240
11/08/11 04:09 AM
11/08/11 04:09 AM
Il
1ol74charger4me Offline OP
Il
My master cylinder is really looking crusty so I'm either going to rebuild and clean it up or replace it. Can somebody tell me where to find the date code so that I don't waste time doing up an incorrect mc. Thanks for any help. This is for a 74 Charger.
Re: date code on master cylinder [Re: 1ol74charger4me] #1109241
11/08/11 01:30 PM
11/08/11 01:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'm not sure they were stamped in the casting, a lot had a small tag on the wire with the mc info,
Re: date code on master cylinder [Re: 1ol74charger4me] #1109242
11/08/11 01:33 PM
11/08/11 01:33 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's stamped in the snout and it's really small IIRC.
Re: date code on master cylinder [Re: Morty426] #1109243
11/08/11 02:08 PM
11/08/11 02:08 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
The datecode info can be found in one of several different locations. The date code tag like Mike showed was found on some Bendix disc brake master cylinders up into some time in 1969. Some master cylinders from the '70s had a bale wire tag too, but on those, the tag had the last 4 numbers of the Chrysler part number, "PWR" if it was a power brake master cylinder, and another couple numbers that I am not sure what they were but don't seem to correspond to any date code.
The datecodes starting in sometime in 1969 were metal stamped into the casting for all master cylinders. I think they were stamped on some pre-69 ones too, like the drum brake with bolted on cap style.
The date code stamp was usually on the side of the casting that was closest to the driver side inner fender. But as Chris said, it sometimes is on the nose of the casting. The date code is 4 numbers, day of the year and one number for the year. 0 123 would be the 123rd day of 1970 (or 1980) though on some with the date code on the nose its reversed, like 123 4 meaning 123rd day of '74.
Many NOS master cylinders have stickers, stencils or even are stamped "made in Canada". I suspect the differences in date codes were different plants. Most were probably made in Canada, but some of the high volume ones like the '67-70 bolt on cap drum brake and the disc brake master used on most '71-'75 Mopars were made both in Canada and some other Bendix plants, and the different plants had somewhat different procedures of putting production marks on their product.
Re: date code on master cylinder [Re: Mastershake340] #1109244
11/08/11 03:25 PM
11/08/11 03:25 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
i did not fine any date codes on my 1971 disc brake master cylinder
pn number 3461187
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: date code on master cylinder [Re: 440beep] #1109245
11/08/11 03:29 PM
11/08/11 03:29 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I can't see any dates on my original 73 either. Just a cast number on the bottom of the master. I suppose a light stamp could have corroded away though.
Re: date code on master cylinder [Re: burdar] #1109246
11/08/11 03:55 PM
11/08/11 03:55 PM
Crook County, ILL
Crook County, ILL
Re: date code on master cylinder [Re: Mastershake340] #1109247
11/08/11 03:58 PM
11/08/11 03:58 PM
Crook County, ILL
Crook County, ILL
Re: date code on master cylinder [Re: Mastershake340] #1109248
11/08/11 04:10 PM
11/08/11 04:10 PM
Crook County, ILL
Crook County, ILL
Datecode tag like the one shown on Mike's roadrunner. I've only seen date code tags on '67-'69 manufactured MC's. This one is 9043, which would be the 43rd day of '69.
Re: date code on master cylinder [Re: Mastershake340] #1109249
11/08/11 09:40 PM
11/08/11 09:40 PM
Il
Il
Great info guys, Thanks.
Re: date code on master cylinder [Re: 1ol74charger4me] #1109250
11/13/11 11:50 AM
11/13/11 11:50 AM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
there is only one mopar brake expert..who gives all answers freely and they are correct ..you can take it to the bank
..817 691 5996 wayne@theramman.com
Re: date code on master cylinder [Re: Mastershake340] #1109251
11/13/11 12:00 PM
11/13/11 12:00 PM
TheRamMan Offline
TheRamMan  Offline
about mid 69..aluminum tags were gone...1st line on port side of disc cylinders....internal bendix jargon
2nd line year(first digit).. next 3 digits day of year...then A B C
WAS SHIFT
the 71 up had tag again..with part #
the double hump( bolt on lid ) not flat lid(repro)..were stamped sporadically...NOT EVERY ONE
all answrs are free and immediate with a call..wayne brown the ram man
is here to anwer your brake qustion freely..and ohnestly..and correctly
817 691 5996
