ignition problem
#1109095
11/08/11 01:09 AM
11/08/11 01:09 AM
Posts: 905 SD
zrxkawboy
SD
My 67 Belvedere (which has electronic ignition) has began to die intermittently. I sure don't like to throw parts at a problem w/o diagnosing it, but the car always starts right back up, making troubleshooting near impossible. I am thinking ignition module. Thoughts?
It's Swifty! Swifty, you toad sucker!
Re: ignition problem
[Re: zrxkawboy]
#1109096
11/08/11 02:20 AM
11/08/11 02:20 AM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi 1 check that the ecu is grounded good 2 replace the resistor 3 could be eather ecu or distributor pick up if above does not cure it
[Re: DartGTS]
#1109098
11/08/11 10:03 AM
11/08/11 10:03 AM
Posts: 905 SD
zrxkawboy
SD
I should have mentioned when I posted that I had removed the ECU mounting screws and checked for a clean connection, and yes, I had used lockwashers when I did the conversion many years ago. Everything looked good. The way I see it, it could be resistor, ECU, pickup coil, or coil. I realize I'll probably have to just start swapping parts, but wondered what was most likely, in your experience. I will test the ECU later at NAPA, but since it's an intrmittent problem, I don't expect anything to show up. Thanks for the replies!
[Re: RapidRobert]
#1109100
11/08/11 12:22 PM
11/08/11 12:22 PM
Posts: 905 SD
zrxkawboy
SD
It doesn't just die at idle, but at any engine speed. There's no miss or anything - it just dies suddenly. Yes, I'll probably swap on a different ECU tonight.
