What Stall and Gear Ratio?? #1108808
11/07/11 05:42 PM
11/07/11 05:42 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
Hello ,
Looking for suggestions on Stall and gear ratio.
I have a 65 coronet currently has 340/727/513 rear.
My 60 foot is a horrible 2.3 seconds. I am using what I had to run. The motor is approx 500 flywheel HP. I am going to change to either a 4.30/4.56. Plus go with a 4000 stall . Anyone running a heavy car with a small block combo that works? Any suggestions I am new at this and dont want to spend a ton doing it twice to get the best combo.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: What Stall and Gear Ratio?? [Re: 65 NSS 500] #1108809
11/07/11 06:19 PM
11/07/11 06:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont have a smallblock as I run a 440 stroker now in my 63. But I use 4.30's with a 30 x 9 tire and a 9.5 Dynamic street/strip converter that flashes about 4200 and drives great on the street. Ron
Re: What Stall and Gear Ratio?? [Re: 65 NSS 500] #1108810
11/07/11 07:31 PM
11/07/11 07:31 PM
Az
Crizila Offline
Crizila  Offline
Az
4.56 and 4500 stall would be good. I run a 4000 lb car also with a small block 408. 4.56 gear, 29" tire, and 3500 stall convertor shifting at 6500 with 60 foot times @ 1.68. 3500 stall isn't enough convertor for my set up and I am looking to go to a 4500 convertor. Depending on where you are shifting, you could even go to a 5000 stall convertor IMO.
Re: What Stall and Gear Ratio?? [Re: Crizila] #1108811
11/07/11 11:23 PM
11/07/11 11:23 PM
Northampton Pa
Northampton Pa
I was thinking the 4.56 but I have stock wheel wells and was not sure how tall a tire I can get. I am shifting at 7000rpm. I was thinking of going to Dynamic for a convertor. Thanks
Re: What Stall and Gear Ratio?? [Re: 65 NSS 500] #1108812
11/09/11 01:02 AM
11/09/11 01:02 AM
Northern Illinois
Dusted U Offline
Dusted U  Offline
Northern Illinois
Tight 3500 stall 410gear 28x14.50 15 hoosier's qtp
You've run your mouth, Now it's time to run your car!!
