Electrical Distribution Block Options #1108613
11/07/11 09:55 AM
11/07/11 09:55 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am looking at adding an electrical distribution block under by dash to feed some extra components. I want something that I can feed 12v battery supply into it and then I can add circuits off of it as needed. I am not looking for a fuse block, but just an electrical distribution strip with maybe 4 connections or so that I can add inline fused circuits later as required. What are my options at the local parts stores?
Where should I wire the 12v feed in from on the car (70 Challenger)?
Re: Electrical Distribution Block Options [Re: YO7_A66] #1108614
11/07/11 11:37 AM
11/07/11 11:37 AM
Hampden, Maine
Procommuter Offline
super street
Procommuter  Offline
super street
Hampden, Maine
Try waytekwire.com, they do have a minimum order on some items.
Wes 73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
Re: Electrical Distribution Block Options [Re: Procommuter] #1108615
11/07/11 12:30 PM
11/07/11 12:30 PM
Colorado
68FuryIIIColo Offline
Colorado
You can use something like these:
http://www.ebay.com/itm/DISTRIBUTION-BLO...=item3f0fce7ce1
http://www.ebay.com/itm/DISTRIBUTION-BLO...=item415f1a01d5
http://www.ebay.com/itm/Raptor-1-4-Way-A...=item1c209bacba
They take a single heavy gauge wire in and 4 smaller gauge out. They are pretty big so maybe it's overkill. Allot of people do just a small fuse block and add fuses as they expand like this:
http://order.waytekwire.com/productdetail2/M50/46080/FUSE%20BLOCK%20WITH%20COVER%20%20%204%20FUSE/
Re: Electrical Distribution Block Options [Re: 68FuryIIIColo] #1108616
11/07/11 01:05 PM
11/07/11 01:05 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
The fuse block appears to be an easy solution.
Thank you both.
