Champion radiators - any good? #1108582
11/07/11 07:35 AM
11/07/11 07:35 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Your ?
Any experiences with quality, fit service etc appreciated
Re: Champion radiators - any good? [Re: Moparmal] #1108583
11/07/11 11:11 AM
11/07/11 11:11 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I put one for a B-Body in my 71 Demon.I had a 71 Fury 26" copper rad in it before,so it dropped right in.Cools fine and the 26" OEM fan shroud screwed right on too.
Nautilus Racing-
Re: Champion radiators - any good? [Re: Chris2581] #1108584
11/07/11 11:59 PM
11/07/11 11:59 PM
Moparmal Offline OP
Moparmal  Offline OP
OK thanks - Any other reviews out there?
Re: Champion radiators - any good? [Re: Moparmal] #1108585
11/08/11 12:33 AM
11/08/11 12:33 AM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
I put a three row with 2-12" fans on my 68 Charger and haven't had any problems the bolt holes on the mounting tabs on the radiator didn't line up but wasn't that big of a deal. For the money you save I'd buy another one any day.
Re: Champion radiators - any good? [Re: KY Charger] #1108586
11/08/11 02:27 AM
11/08/11 02:27 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks - thats valuable info.
Re: Champion radiators - any good? [Re: Moparmal] #1108587
11/08/11 03:28 AM
11/08/11 03:28 AM
Canada
CrAzYMoPaRGuY Offline
Canada
The rad I got looks great. 26", three core. Three of the four mounting bolts lined up. Other than that. it seems to fit decently. I won't know about actual cooling for a couple of weeks though.....
CrAzYMoPaRGuY
Re: Champion radiators - any good? [Re: CrAzYMoPaRGuY] #1108588
11/08/11 05:31 AM
11/08/11 05:31 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
My dad put one in my moms barracuda...all but one mounting hole lined out (seems like a common issues?)
Works and looks great, no complaints.
Re: Champion radiators - any good? [Re: Moparmal] #1108589
11/08/11 10:01 AM
11/08/11 10:01 AM
Maryville tn
67coronetman Offline
Maryville tn
Seem everyone so far has something good to say .! Well my friend put on in his car three core & it want cool at all period he has tried everything.!
Old car are me......
Re: Champion radiators - any good? [Re: 67coronetman] #1108590
11/08/11 11:26 AM
11/08/11 11:26 AM
More details (everything), maybe we can help him
Re: Champion radiators - any good? [Re: 67coronetman] #1108591
11/08/11 11:53 AM
11/08/11 11:53 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
A new radiator of sufficient size is NOT the answer alone. IF the car is cooling well at highway or normal driving speeds,the rad is doing it's job. If not cooling in traffic,the rad is not getting enough airflow to cool.(this is taken un consideration a head gasket or cracked cylinder is not the issue causing heat problems) A proper fan and shroud are the two other most important parts. I had an aluminum rad, and a 6 blade fan...with shroud and it didn't work in traffic or idling. I installed a 7 blade steel clutch fan with shroud and champion rad and it cools very well.
I have used 3 champion radiators and feel they are exceelent value..best bang for the buck.
Re: Champion radiators - any good? [Re: terzmo] #1108592
11/09/11 07:49 AM
11/09/11 07:49 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks Terzmo - I intend running a shroud and a clutch fan.
Re: Champion radiators - any good? [Re: Moparmal] #1108593
11/09/11 10:47 PM
11/09/11 10:47 PM
Export, PA
jayyohe Offline
jayyohe  Offline
Export, PA
I have one in my 71 Demon and although I have not had the car on the road yet, I let it idle in the driveway and it seems to cool just fine.
jayyohe@yahoo.com Export, PA 1971 Dodge Demon - 440/4-Speed
Re: Champion radiators - any good? [Re: jayyohe] #1108594
11/09/11 11:09 PM
11/09/11 11:09 PM
I love the Champs --best value out there even if they are not perfect--My last one had a little " twist" in it but a few washers and away we went COOL as a Cuke!
Re: Champion radiators - any good? [Re: ] #1108595
11/09/11 11:39 PM
11/09/11 11:39 PM
Hazlet, NJ
440Satellite Offline
super gas
super gas
Hazlet, NJ
Just put a 26" 3 row in my 72 Duster. I bought a complete 360 from a guy who was having idleing problems as well as saying it ran hot. I think it may have been an ignition problem but I dropped it in along with the Champion rad and it never goes over 180 without a fan shroud. So I'm very impressed with the cooling. Now the bad... mine came twisted and on recomendation from the seller, I stood on the 2 corners and it did straighten it out. But now that its in the car, it has a slight leak from somewhere in the cooling fins. I'm sending it back for a replacement but it does leak. Overall I'm happy with it, theres always a chance of a defect in anything you buy.
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Champion radiators - any good? [Re: 440Satellite] #1108596
11/11/11 01:05 PM
11/11/11 01:05 PM
I just got mine last week and it looks great, nice thick construction. I went with a 4 row and the shroud and two 12" fans and all for less than $500 delivered.
Re: Champion radiators - any good? [Re: ] #1108597
11/11/11 02:11 PM
11/11/11 02:11 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
I have a 4-row in my Demon. Awesome radiator for the price! Now, if I didn't have a cracked head or blown head gasket I could reap the benefit of it...
I did have to bore out a couple of the holes to get it to fit right, but nothing a Dremel and five minutes couldn't handle. Otherwise, it fits great!
Re: Champion radiators - any good? [Re: Hotwheelsjr] #1108598
11/11/11 02:25 PM
11/11/11 02:25 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
I have no experience with the Champion radiator but from the posts it appears to be good.
I am running an alum. radiator, (2) 1 1/4" tubes , in my street Hemi cuda with no water pump fan. Car stays at 180 degrees while in motion and the electric fan kicks on at 200 degrees when stuck in traffic. Brings it back down to 180 degrees in nothing flat.
Smiths radiator out of Cambridge City, Indiana built mine and he specializes in Mopars. Don't remember the price but he produces great radiators too.
Re: Champion radiators - any good? [Re: Mopar Grandpa] #1108599
11/11/11 06:25 PM
11/11/11 06:25 PM
Tri-Cities, Washington
V
VITC_GTX Online content
VITC_GTX  Online Content
V
I have a Champion in my '70 Sport Satellite with warm 383 and it's seems to work just fine. Both of the tranny cooler fittings (flare) where smashed flat under the nut that was on the fitting during shipping. This means it was done during construction/storage but I was able to get them round enough not to leak.
I just looked and Summit has a crossflow (18"X22.5" core) for $144. I have one of these in my Demon and it works very well. Construction seems to be a little higher quality (welds anyway). I called Summit and confirmed that they are welded tanks and not epoxy. They don't have petcock or mounting tabs but that's not hard or expensive to take care of.
Re: Champion radiators - any good? [Re: VITC_GTX] #1108600
11/11/11 07:23 PM
11/11/11 07:23 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I just recv'd mine look good i will install it this weekend
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Champion radiators - any good? [Re: 67mprfan] #1108601
11/11/11 08:39 PM
11/11/11 08:39 PM
Moparmal Offline OP
Moparmal  Offline OP
Thanks for the replies - I ordered a 3 core - $120 shipping to Australia ain't bad at all.
I'll dredge this thread up and comment when I receive it and check it out.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
