Re: Front Blackout Paint; What do you recommend.
[Re: Challenger 1]
#1108385
11/07/11 12:46 PM
11/07/11 12:46 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: RoadRunnerJD]
#1108388
11/07/11 01:22 PM
11/07/11 01:22 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Organisol was not used. OE looks like a DP90 primer. I use Krylon Semi-flat.
I just used DP90 - looks great
[Re: RoadRunnerJD]
#1108389
11/07/11 01:32 PM
11/07/11 01:32 PM
Posts: 21,541 N.E. OHIO, USA
A12
N.E. OHIO, USA
John, that's what I used too on the GTX (Krylon Semi-FLAT) Didn't care if it was done right (coverage area) as long as you couldn't see the Y2 behind the grill like before I blacked it out. Those are factory paint runs on the original Y2 paint under the blackout
MikeR
[Re: A12]
#1108390
11/07/11 03:19 PM
11/07/11 03:19 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
John, that's what I used too on the GTX (Krylon Semi-FLAT) Didn't care if it was done right (coverage area) as long as you couldn't see the Y2 behind the grill like before I blacked it out. Those are factory paint runs on the original Y2 paint under the blackout :biggrin MikeR
That looks good! The black seems to match OE pretty nicely. The thing I like about the Krylon is that it's a spray bomb, you don'thave to mix it. Also, I had to redo my blackout a couple of times before I was happy with it. I was able to wash it off with thinner without damage to the urethane.
[Re: ph23vo]
#1108393
11/08/11 02:49 AM
11/08/11 02:49 AM
Posts: 5,447 So Cal
Sinitro
So Cal
Checkout Black Satin.. The satin finish has a slight sheen to it, more attractive then semi-flat... Just my $0.02..
[Re: Sinitro]
#1108394
11/08/11 10:48 AM
11/08/11 10:48 AM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Just my $0.02..
could you be more specific?
is "Black Satin" the brand name? Does in come in a rattle bomb or something that can be squirted through a gun? Thanks for any help.
[Re: LimeliteAero]
#1108395
11/08/11 11:03 AM
11/08/11 11:03 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Here is a shot of an untouched original 5000 mile car. Notice the paint and try to duplicate it. Looks like it does have a slight sheen to it.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: LimeliteAero]
#1108396
11/08/11 12:30 PM
11/08/11 12:30 PM
A12
N.E. OHIO, USA
Just my $0.02..
Krylon also has Black Satin finish paint, I think that's what is being suggested?
[Re: LimeliteAero]
#1108398
11/08/11 12:57 PM
11/08/11 12:57 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Just my $0.02..
Major paint suppliers carry Black Satin including Rustoleum.. The Satin finish is more attractive than semi-gloss or flat, as it has about a 25% gloss added. Also because of its slight sheen it has a more equal distributed pattern when applied. It is available in rattle-cans or liquid cans such as quarts or pints.
Try a can and apply to a random part and compare side-by-side to a part finished in flat or semi-gloss, you will like the better appearance of the Satin.. Guaranteed!!
Just my $0.02..
