Front Blackout Paint; What do you recommend. #1108382
11/06/11 11:08 PM
11/06/11 11:08 PM
Fremont, CA.
Topcat Offline OP
Topcat  Offline OP
Fremont, CA.
Car is a 71 Cuda'.
Coming out of paint booth sometime this month.
Would like the best correct front blackout color like what OEM used. (correct black hue)
Anyone have the right color code mixture?
Was Organasol used?
Thanks in advance.
Re: Front Blackout Paint; What do you recommend. [Re: Topcat] #1108383
11/06/11 11:47 PM
11/06/11 11:47 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I'd love to know myself. If anyone has a paint formula that would help immensely.
Re: Front Blackout Paint; What do you recommend. [Re: Topcat] #1108384
11/07/11 10:57 AM
11/07/11 10:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
imo, this is the best match.
Re: Front Blackout Paint; What do you recommend. [Re: Challenger 1] #1108385
11/07/11 12:46 PM
11/07/11 12:46 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
That's what I used.
Re: Front Blackout Paint; What do you recommend. [Re: Challenger 1] #1108386
11/07/11 12:59 PM
11/07/11 12:59 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Organisol was not used. OE looks like a DP90 primer. I use Krylon Semi-flat.
Re: Front Blackout Paint; What do you recommend. [Re: Challenger 1] #1108387
11/07/11 01:19 PM
11/07/11 01:19 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Front Blackout Paint; What do you recommend. [Re: RoadRunnerJD] #1108388
11/07/11 01:22 PM
11/07/11 01:22 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I just used DP90 - looks great
Re: Front Blackout Paint; What do you recommend. [Re: RoadRunnerJD] #1108389
11/07/11 01:32 PM
11/07/11 01:32 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
John, that's what I used too on the GTX (Krylon Semi-FLAT) Didn't care if it was done right (coverage area) as long as you couldn't see the Y2 behind the grill like before I blacked it out. Those are factory paint runs on the original Y2 paint under the blackout
MikeR
Re: Front Blackout Paint; What do you recommend. [Re: A12] #1108390
11/07/11 03:19 PM
11/07/11 03:19 PM
Warrenton, VA
Warrenton, VA
John, that's what I used too on the GTX (Krylon Semi-FLAT) Didn't care if it was done right (coverage area) as long as you couldn't see the Y2 behind the grill like before I blacked it out. Those are factory paint runs on the original Y2 paint under the blackout :biggrin
MikeR
That looks good! The black seems to match OE pretty nicely. The thing I like about the Krylon is that it's a spray bomb, you don'thave to mix it. Also, I had to redo my blackout a couple of times before I was happy with it. I was
able to wash it off with thinner without damage to the urethane.
Re: Front Blackout Paint; What do you recommend. [Re: RoadRunnerJD] #1108391
11/07/11 05:43 PM
11/07/11 05:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Remember to spray it from an angle under the car; originally the blackout was done by a guy in a pit as the car rolled along above him. Either the Trim Black or Krylon Semi will look fine if you get the "pattern" right; rest assured Chrysler didn't spend any more than necessary for the paint they used, though it was doubtless applied by spraygun.
Re: Front Blackout Paint; What do you recommend. [Re: A12] #1108392
11/07/11 09:10 PM
11/07/11 09:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
krylon semi-flat did it 23 yrs ago still looks great! dan
Re: Front Blackout Paint; What do you recommend. [Re: ph23vo] #1108393
11/08/11 02:49 AM
11/08/11 02:49 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Checkout Black Satin..
The satin finish has a slight sheen to it, more attractive then semi-flat...
Just my $0.02..
Re: Front Blackout Paint; What do you recommend. [Re: Sinitro] #1108394
11/08/11 10:48 AM
11/08/11 10:48 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Just my $0.02..
could you be more specific?
is "Black Satin" the brand name? Does in come in a rattle bomb or something that can be squirted through a gun?
Thanks for any help.
Re: Front Blackout Paint; What do you recommend. [Re: LimeliteAero] #1108395
11/08/11 11:03 AM
11/08/11 11:03 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a shot of an untouched original 5000 mile car. Notice the paint and try to duplicate it. Looks like it does have a slight sheen to it.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Front Blackout Paint; What do you recommend. [Re: LimeliteAero] #1108396
11/08/11 12:30 PM
11/08/11 12:30 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Just my $0.02..
Krylon also has Black Satin finish paint, I think that's what is being suggested?
Re: Front Blackout Paint; What do you recommend. [Re: A12] #1108397
11/08/11 12:53 PM
11/08/11 12:53 PM
PEI Canada
chromedome426 Offline
PEI Canada
Black satin is basically a shade of black paint. For Example: There is flat black, satin black, semi gloss black and then gloss black.
Re: Front Blackout Paint; What do you recommend. [Re: LimeliteAero] #1108398
11/08/11 12:57 PM
11/08/11 12:57 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just my $0.02..
Major paint suppliers carry Black Satin including Rustoleum..
The Satin finish is more attractive than semi-gloss or flat, as it has about a 25% gloss added. Also because of its slight sheen it has a more equal distributed pattern when applied. It is available in rattle-cans or liquid cans such as quarts or pints.
Try a can and apply to a random part and compare side-by-side to a part finished in flat or semi-gloss, you will like the better appearance of the Satin.. Guaranteed!!
Just my $0.02..
Re: Front Blackout Paint; What do you recommend. [Re: Sinitro] #1108399
11/08/11 01:32 PM
11/08/11 01:32 PM
SE Pa.
SE Pa.
I guess I was just being stupid....I thought there was a new paint product line out called "Black Satin".
