Re: 4 -speed question
[Re: moparcyco]
#1108173
11/06/11 09:37 PM
11/06/11 09:37 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Can a ball and trunion style 4-speeed tailhousing be converted to a slip yoke easily?or is there a bunch o f stuff need to be done.I need a 4 speed for my car,found a 65 out of a coronet.I will rebuild whatever I find so it will be apart but if it requires a bunch if extra parts I may continue my search.Thanks Guys
I agree with 68 LAR has already siad, what car are you wanting to use it in now? It makesa difference, the 1966 to 1969 B bodys are the same, the 1970 and up B and E body share the tailshaft housing but the trans tail shaft mounting position and shifter pads are in differnent locations than the earlier B body are. BTW, I have both PM me if you want on this Cab
