340 rockers Lacking oil on drivers side #1108093
11/06/11 03:23 PM
11/06/11 03:23 PM
Kansas
racincuda Offline OP
Kansas
340 rockers Lacking oil on drivers side, fresh engine, Plugs all seem to be in place, pass side oils great but not drivers side, cam bearings properly installed, wat am I missing
Re: 340 rockers Lacking oil on drivers side [Re: racincuda] #1108094
11/06/11 03:26 PM
11/06/11 03:26 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if you are priming the engine..you need to slowly rotate the engine while priming...
the oil holes in the cam lines up at different points from the left and right side of the engine.
Tony
70 AARCuda Vitamin C
Re: 340 rockers Lacking oil on drivers side [Re: 70AARcuda] #1108095
11/06/11 03:54 PM
11/06/11 03:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you are currently rotating the engine while priming still getting little or no oil to the top on one side your rocker shaft may be in wrong. the shaft should have the notches on the end down and forward on the left (drivers) side and down and to the rear on the right side of the engine.
Re: 340 rockers Lacking oil on drivers side [Re: MoparforLife] #1108096
11/06/11 04:34 PM
11/06/11 04:34 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Is the rocker shaft positioned right? Notch to the rear on right side and to the front on the left bank?
Moparforlife beat me. read....
Re: 340 rockers Lacking oil on drivers side [Re: T2R9] #1108097
11/06/11 04:57 PM
11/06/11 04:57 PM
Kansas
Kansas
Hughes rocker shafts and the engine is running, I guess i will ck shaft position but pretty sure that it's correct.
Re: 340 rockers Lacking oil on drivers side [Re: racincuda] #1108098
11/06/11 05:11 PM
11/06/11 05:11 PM
What they said; (1) cam bearing (you are sure that's right) (2) head gasket oil hole not punched (extremely rare) (3) 2nd from front dr pedestal prob (bolt/shaft hole issue or clogged) (4) shaft orientation (you were sure of that) (5) shaft plugged up (could be but it is new) EDIT Since you're dead in the water I'd pull the plugs and have a helper down below hand turn the crank with a 1&1/4" socket/short extension/breaker bar as you up top (re) drill prime & hopefully get oil when he hits the sweet spot (cover the pedestal w a rag if the shaft is off). Never had that accident but seen it happen
