Stock iron 440 intake egr question... #1107953
11/06/11 02:49 AM
11/06/11 02:49 AM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
I have an intake that has the egr plate on it, but has a hole on the bottom of each runner, will exhaust gas get into the intake????
Re: Stock iron 440 intake egr question... [Re: Blown61] #1107954
11/06/11 09:04 AM
11/06/11 09:04 AM
scratchnfotraction Offline
not if it has the egr block off plate is bolted to the intake
Re: Stock iron 440 intake egr question... [Re: scratchnfotraction] #1107955
11/06/11 09:28 AM
11/06/11 09:28 AM
moparx Offline
moparx  Offline
if you are worried about those "jet" holes, they can be tapped for 1/4 or 3/8 pipe[i forget which size]and use a hex plug to fill 'em. if there is a big "jet" hole i one runner, you will have to detirmine the size and tap accordingly for a larger pipe tap size, or a normal bolt size. if using a bolt, machine the head to approximately 1/8" thick to minimize flow restriction.
