UNIBODY VS FRAME #1107940
11/06/11 12:55 AM
11/06/11 12:55 AM
USA
DAK512 Offline OP
DAK512  Offline OP
USA
Is there a advantage to having a frame over a unibody?
Re: UNIBODY VS FRAME [Re: DAK512] #1107941
11/06/11 01:35 AM
11/06/11 01:35 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
You can lift the body off the frame, build your suspension with the engine and everything in the car and then set everything down on top of it. Always pros and cons in everything.
Re: UNIBODY VS FRAME [Re: DAK512] #1107942
11/06/11 08:13 AM
11/06/11 08:13 AM
gregsdart Offline
gregsdart  Offline
Unibody is lighter in stock form, once you go full tube chassis that advantage would be gone.
Re: UNIBODY VS FRAME [Re: DAK512] #1107943
11/06/11 09:00 AM
11/06/11 09:00 AM
Locomotion Offline
Locomotion  Offline
Putting frame connectors in a unibody goes a long way in strengthening the frame to reduce flex and improve weight transfer. Either style needs to be topped off with at leat a 6-8 point roll bar for even better efficiency. I'm just guessing, but with a unibody, you can add reinforcements only where it's needed most to save weight.
