Page 10 of 10 1 2 8 9 10
Re: How is your progress ? [Re: moparx] #1107934
05/31/12 09:58 PM
05/31/12 09:58 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
mark, here is a pic of where that chassis tube goes. i've been looking at bumpstops, but for some reason the ones i've seen that i think i want don't show the size specs [hint,hint prothane......]. it appears they are approximately 1 1/2" dia. x approximately 1/2- 3/4 thick[?] with a couple of center bolt bushings that appear to be for 3/8" bolts.
Hey Eric,
I can look through some catalogs for you if that is the size you are looking for?
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: How is your progress ? [Re: Hemi Allstate] #1107935
06/01/12 01:48 PM
06/01/12 01:48 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Thanks Mark, the plan is for a 360 with J heads and a mild cam,727 with a manual valve body. it has a "B" body 8 3/4 rear with 3.23 gears. 4 bar setup in the rear and a mustang II frontend with tube A arms.
I also have a set of halibrand style wheels for it (I just have to get them back from my son)
I have a bed that needs to be shortened and all the fenders.
I have most everything to finish this truck sio that is why it got moved up on the to do list
I hope to get this truck and the race truck finished befor fall(wish me luck) Ron....
Re: How is your progress ? [Re: Hemi Allstate] #1107936
06/03/12 07:43 AM
06/03/12 07:43 AM
moparx Offline
moparx  Offline
Hey Eric,
Mark
thanks mark! they need to be no bigger than 1 5/8" od x 1" tall with a single mounting stud or bolt. if they were 1/2 to 3/4 tall, that would be even better. but i can trim them down in height if necessary.
Re: How is your progress ? [Re: Mopar Ron] #1107937
06/03/12 12:13 PM
06/03/12 12:13 PM
Mt. Eden Ky.
Mt. Eden Ky.
Ron,
That is going to be a really cool truck!
I don't doubt that you will get them both done either!
1996 Ram 1500 Sport
1968 road runner
Re: How is your progress ? [Re: moparx] #1107938
06/03/12 12:18 PM
06/03/12 12:18 PM
Mt. Eden Ky.
Mt. Eden Ky.
What type of material are you looking for Eric? Can it be rubber?
Mark
1996 Ram 1500 Sport
1968 road runner
Re: How is your progress ? [Re: Hemi Allstate] #1107939
06/04/12 09:19 PM
06/04/12 09:19 PM
moparx Offline
moparx  Offline
rubber would work, but polyurethane would be better unless it was too hard. um...... no bright colors if possible.
