Re: 440 spark plug wire clearance issue [Re: sunroofgtx] #1107703
11/09/11 03:21 AM
11/09/11 03:21 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
I really felt like beating on something today If it works it will be good for a while. I might have a look at Accel shortie plugs later. When I get all the bugs out I will likely upgrade the heads and headers.
If you post some pics up, I'm sure can can help with what boots might work better. I've got hundreds of pics of different header/boot combo's. Just not sure on the type of some of the headers. I can send you some boots if you decide you need some higher temp. Don't hammer on your headers if all it will take is a different boot.
Kinda hard to get any good close ups.
Re: 440 spark plug wire clearance issue [Re: 62440] #1107704
11/10/11 12:00 PM
11/10/11 12:00 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that boot type is for stock mounting locations which you won't be able to easily do with headers.
