Aluminum cells and today's pump gas or E-85
#1107670
11/05/11 07:33 PM
11/05/11 07:33 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Hello, Mr paranoid here. What about the new fuel cells by Aeromotive. Aluminum cell, aluminum pump housing (submerged), filter submerged. Is this a longish term concern w/E-10 fuel? How about with E-85? Thanks Curt
Oh yeah...THAT'S gonna leave a mark!
Re: Aluminum cells and today's pump gas or E-85
[Re: Curt]
#1107672
11/05/11 08:13 PM
11/05/11 08:13 PM
Posts: 22,696 Bitopia
jcc
Bitopia
However the biggest issue is moisture, which breaks the fuel down to acids, which is what causes all the damage. So if different owners have different moisture, air, humidity, contamination, etc, each IMO will likely have different results.
[Re: jcc]
#1107673
11/05/11 08:25 PM
11/05/11 08:25 PM
Posts: 16,493 On the run…
BloFish
On the run…
So the drier, the better?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#1107674
11/05/11 09:36 PM
11/05/11 09:36 PM
jcc
Bitopia
Yup, but I'm not sure how possible that is without a completely sealed system.
[Re: 69dart]
#1107676
11/06/11 10:18 PM
11/06/11 10:18 PM
Curt
JAX FLA
Yeah, I live in florida so humidity is severe. There is probably 1 or 2 days a month I don't have to use the wipers before leaving for work... Thanks, Curt
