8 3/4 small yoke to big yoke? #1107599
11/05/11 03:25 PM
11/05/11 03:25 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
Question, If I have a 742 case, clutch SG 3.23 geared diff. can I switch from a small yoke to a big yoke?
Re: 8 3/4 small yoke to big yoke? [Re: wvmarv] #1107600
11/05/11 05:13 PM
11/05/11 05:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
if the spline count matches its doable,,, you need to match the torque on the pinion nut. why dont you get the conversion U joint? much less work..
I am truckless..
Re: 8 3/4 small yoke to big yoke? [Re: wvmarv] #1107601
11/05/11 05:17 PM
11/05/11 05:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes you can, the 742 doesn't have a crush sleeve , off with the old on with the new, RTV on the splines after you clean them andredloctite on the nut.
Re: 8 3/4 small yoke to big yoke? [Re: JohnRR] #1107602
11/05/11 06:30 PM
11/05/11 06:30 PM
WV,USA
W
wvmarv Offline OP
wvmarv  Offline OP
W
WV,USA
Thats what I thought, as long as spline count was the same. Never heard of RTV on the splines though. What is the yoke nut torque setting?
