Re: rear wheel bearing??
[Re: plymguy]
#1107155
11/04/11 07:03 PM
11/04/11 07:03 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
One of my '67 Plymouth Furys needs a rear wheel bearing. I am referring to the bearing on the flange end of the axle. I seem to remember that you used to be able to purchase a kit that included the bearing, both seals, the retainer ring and some even included the metal plate that is fastened to the axle housing. Does anyone know where I can find one of these kits? Also are the bearings the same on both sides? It is an 8 3/4 rear end. Thanks for any help. John
http://www.doctordiff.com/ he's a member here
[Re: plymguy]
#1107157
11/04/11 09:07 PM
11/04/11 09:07 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The kit you are looking for has not been available for years , you can buy the bearing and seals , you can pull the old bearing by taking it apart and not ruin the retaining plate , it takes some work .
[Re: JohnRR]
#1107158
11/04/11 09:44 PM
11/04/11 09:44 PM
RapidRobert
pretty sure the bearings are the same but the pass retainer plate is threaded for adjusting the play. yes contact the Doc
