rear wheel bearing?? #1107153
11/04/11 06:31 PM
11/04/11 06:31 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
One of my '67 Plymouth Furys needs a rear wheel bearing. I am referring to the bearing on the flange end of the axle. I seem to remember that you used to be able to purchase a kit that included the bearing, both seals, the retainer ring and some even included the metal plate that is fastened to the axle housing. Does anyone know where I can find one of these kits? Also are the bearings the same on both sides? It is an 8 3/4 rear end. Thanks for any help.
John
Re: rear wheel bearing?? [Re: plymguy] #1107154
11/04/11 06:43 PM
11/04/11 06:43 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
I go through Randys Ring and Pinion.
Re: rear wheel bearing?? [Re: plymguy] #1107155
11/04/11 07:03 PM
11/04/11 07:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
John
http://www.doctordiff.com/ he's a member here
Re: rear wheel bearing?? [Re: mikemee1331] #1107156
11/04/11 08:10 PM
11/04/11 08:10 PM
IN
ahy Offline
ahy  Offline
IN
In addition to Randy's and Dr Diff, a parts store can get the bearings and seals in a day or two if not in stock. Autozone sells Timken.
Re: rear wheel bearing?? [Re: plymguy] #1107157
11/04/11 09:07 PM
11/04/11 09:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John
The kit you are looking for has not been available for years , you can buy the bearing and seals , you can pull the old bearing by taking it apart and not ruin the retaining plate , it takes some work .
Re: rear wheel bearing?? [Re: JohnRR] #1107158
11/04/11 09:44 PM
11/04/11 09:44 PM
pretty sure the bearings are the same but the pass retainer plate is threaded for adjusting the play. yes contact the Doc
