Page 3 of 3 1 2 3
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106963
11/07/11 04:11 PM
11/07/11 04:11 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Thanks for these answers to your post! I just ran a can of Seafoam thru the carb on my 70 383 mag & whatta difference. The 383 sat on a stand for 7 yrs before the install in my 71 Power Wagon & had a big cam that didn't help matters. Low stall verter & tall 35" tires w/ 3.55's got the motor loaded up w/ carbon & suit for the past 8 mos. Poured 1/2 of the can down the carb @ 2000 rpm & then dumped enough to stall it. Let it sit for 15 minutes & fired it up. Smoked big time for a minute & then cleared right up. Truck runs much better & can notice more low end throttle response & smoother idle. Gonna switch the cam soon, but this was a good fix until then. Also put the last 1/4 in the tank.
BTW, I did put some Marvel mystery oil in the plug holes before the install to lube things up, but that was months ago. I also heard Marvel Mystery oil is good for a top end cleaner, too??
Re: Run ATF to clean a gunked motor? [Re: DartGTS] #1106964
11/07/11 04:24 PM
11/07/11 04:24 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Hello:
I'm confused you say the engine was freshly rebuilt 4 years ago and has only been run a few times but not enough to really warm it up. What makes you think it is so dirty you need to do something so drastic? How did it get that bad?
The run on you describe is probly due to not being properly tuned up. Change oil and filter (before starting engine)
Tune it up / drain tank / carb / and lines.
Then see how it runs. MY HUMBLE OPINION
Maynard
I think you are on to something here. First I made the mistake of assuming the fluids were topped off and low and behold, the motor is low on coolant and was begining to run hot. I think the electric fans saved my butt here...motor got up to 220F before I realized the motor was running hot.
Coolant has since been topped off and motor runs at idle at no more than 175 degrees after 30 minutes. The motor now runs a LOT better and I think that was making me think I had tons of crap in the chambers...to be safe, I added Marvel Mystery Oil to fuel and oil.
Issue still remains with engine idling at 1100-1200 RPM and running rich. From what I can see the carb is set to run lean (idle mixture screws are only 1 turn out from being bottomed out) and idle speed is set to lowest...
I am not sure if timing is my cuplrit here or maybe a vacum leak...motor seems to pull a consistant manifold vacum of 15 inches at idle...
Any pointers on where to look? I am a younger guy so I am trying to learn the tuning of a holley carb where I grew up in a world of computers...
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106965
11/07/11 05:07 PM
11/07/11 05:07 PM
scratchnfotraction Offline
you want to make sure the carb is on the idle circut and the curb idle setting is not opening the butterflys to uncover the transition slots makeing it rich at 1200 rpms.
use a timeing light to set base timeing,then use a vac gauge to adjust the air mixture screws to get the highest vac readings,then adjust curb idle,then recheck/adjust all 3 setting agian to dial it in.
if the air scews are that far in and its still fat,i wager it is on the power/crus mode and not the idle circut
I have my 440 dialed in to a 750 rpm idle timeing at 10*BTDC pulls 19 inches of vac
find what the engine likes with the timeing light and vac gauge and adjust acordingly
oh! and change the plugs,they could be fuel fould already,i had mine black and sooted up bad swaping carbs around one time and just need a fresh set of plugs.
Re: Run ATF to clean a gunked motor? [Re: cjskotni] #1106966
11/07/11 06:14 PM
11/07/11 06:14 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Think your on the right path by looking for a mechanical problem, but my experience with Holley Carbs is somewhat limiited. I have always used Carter (now Edelrock Carbs much easier to tune, in my opinion.) I'm sure someone here can help you on the Holley.
Engines are complicated devices and nothing you can pour out of a can will cure a badly tuned or improperly built engine.
That comment is not a reflection on you or your talents, just something to keep in the back of your head.
Maynard
Page 3 of 3 1 2 3
