Soft brake line to rear axle block-70 Cuda #1106895
11/04/11 12:52 AM
11/04/11 12:52 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
The parts houses do not show the soft line that connects to the block mounted on the axle for a 70 Cuda. They show the line for a 71-74 Cudas, though. Is there any reason the 71 line wouldn't work on a 70?
Re: Soft brake line to rear axle block-70 Cuda [Re: Mike H] #1106896
11/04/11 01:48 AM
11/04/11 01:48 AM
The top end that connected to the hard line they would all be 3/16" female inverted flare. If the brass block end was compatible and the hose was long enough you'd be good. With my arched springs I needed a longer one from a 1/2 Ton pickup. Dont have an exact yes or no ans for you but here's a BTT
Re: Soft brake line to rear axle block-70 Cuda [Re: RapidRobert] #1106897
11/04/11 01:55 AM
11/04/11 01:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
At stock height you can use a front brake hose, the rubber section is the same length as stock, the metal fitting at the axle is about 3/4" longer...And the fitting thread size & pitch is the same...
Re: Soft brake line to rear axle block-70 Cuda [Re: 1_WILD_RT] #1106898
11/08/11 09:54 AM
11/08/11 09:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
When I did my old 1970 Challenger, I ran into the same issue - no rear hose for 1970 E-body.
I found 1970 B-body was avail. So,,,, thats what I used, never had a problem
I think the 71-74 E-body rear hose has the brass block molded into the hose, where as 1970 models the block is a seperate piece
