trans swap
#1106887
11/04/11 12:10 AM
11/04/11 12:10 AM
Posts: 905 SD
zrxkawboy
SD
I'm contemplating swapping a '74 360/727 into my '67 Belvedere, which has a 225/3-spd. I am wondering what I would need for a trans cross-member/mount. I was thinking I could use an aftermarket (cable) shifter and a Bouchillon kickdown kit, and of course, add a cooler. Are there any other trans issues I'm overlooking? Thanks in advance.
It's Swifty! Swifty, you toad sucker!
Re: trans swap
[Re: zrxkawboy]
#1106888
11/04/11 01:51 AM
11/04/11 01:51 AM
RapidRobert
I'd be surprised if the trans crossmember was different, maybe even same mount. No knowledge of the rest
Re: trans swap
[Re: zrxkawboy]
#1106890
11/04/11 07:45 PM
11/04/11 07:45 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 3-speed and the auto use the same rear crossmember, the 4-speed is different.
Re: trans swap
[Re: John_Kunkel]
#1106894
11/04/11 08:52 PM
11/04/11 08:52 PM
Posts: 905 SD
zrxkawboy
SD
Great, thanks John!
