Page 1 of 3 1 2 3
Headers vs HP Manifold #1106827
11/03/11 11:34 PM
11/03/11 11:34 PM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
I have heard that the Original HP manifolds flow really well (much better than brand x original equipment), so I was wondering on a stock BB/RB engine is there any real advantage. I have run headers on most of my other cars (non-mopar) but as stated their original stuff flow like a clogged toilet. Thanks for the advice.
-C
Re: Headers vs HP Manifold [Re: ramman5600] #1106828
11/04/11 01:12 AM
11/04/11 01:12 AM
I've debated this myself whether to mess with headers. Andy made 550 HP w his 470 with HP manifolds/3" mandrel pipes. Way back "Headers by Ed" sold header kits and some custom headers and they quoted an independant study by Hot rod iirc that found a great amount of gain by utilizing equal length pri pipes and that was their big selling point and that's the only thing pushing me toward considering headers as opposed to the HP manifolds or maybe the max wedge manifolds which are even better and have a 3" flange outlet. The BB logs I wouldn't even consider
Re: Headers vs HP Manifold [Re: RapidRobert] #1106829
11/04/11 01:18 AM
11/04/11 01:18 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Headers WILL add horsepower, but with a mild engine the increase is less dramatic. Cast iron manifolds will leak less and keep underhood temps down. I have never run headers and likely never will as I am not looking for every last bit of power.
Re: Headers vs HP Manifold [Re: Jim_Lusk] #1106830
11/04/11 03:49 AM
11/04/11 03:49 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On a stock engine, if you already have the HP manifolds on it, I'd just leave them be. I have headers on mine but my 440 is modded and had the log manifolds on it when I bought the car.
Re: Headers vs HP Manifold [Re: DaytonaTurbo] #1106831
11/04/11 09:03 AM
11/04/11 09:03 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
TTI's. Less weight. Cooler.
Re: Headers vs HP Manifold [Re: DennisH ] #1106832
11/04/11 09:48 AM
11/04/11 09:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
depends on what you have. ANY header will gain HP over Mani's. If you have a mild 440 and the exhaust is already on, I'd leave it alone.
Coming soon!!!!
Re: Headers vs HP Manifold [Re: ramman5600] #1106833
11/04/11 12:25 PM
11/04/11 12:25 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Ahhhh, the old headers vs. manifolds discussion. OK, why not?
- yes headers will usually show a gain over manifolds. how much depends on the motor/build. Expect maybe 10-15 on a street RB.
BUT
- most people fail to consider that the exhaust system is a SYSTEM and the motor doesn't really care WHERE the restriction is. I am positive that my HP manifold/2 1/2 " mandrel bent TTI/Dynomax Ultraflow system flows better than a set of cheapie headers mated to the stock exhaust system.
- People tend to look at this two ways; one person will say why give up the hp using manifolds and another will say that you can get whatever hp you are after using manifolds with the right build. Both are usually correct: it depends on your perspective.
Headers vs. Manifolds
pros - flow better, usually pick up some hp, lighter
cons - most leak, higher underhood temps, full headers can drag, doesn't look stock.
As was said; 500hp can easily be had with manifolds....how much power are you looking for?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Headers vs HP Manifold [Re: DPelletier] #1106834
11/04/11 01:26 PM
11/04/11 01:26 PM
dogdays Offline
dogdays  Offline
A common misconception is that headers only influence the top end.
Another common misconception is that headers only reduce power by reducing restrictions in the exhaust system.
Dyno tests have shown that shorty headers make more power than manifolds and long tube headers make more power than shorties. It has to do with the length of time the exhaust pulse travels in its own tube. A good long tube header will not only increase power above the torque peak, but it also increases torque below the torque peak. This low rpm increase clearly has little to do with flow restriction.
The oldsmobile head is an example. The center two exhaust ports are run together in the head and come out as one wider port which should lower restriction for those two ports. However, it is always advantageous to divide the ports. There is significant cross-talk between the two which interrupts something, probably scavenging during overlap. Flathead fords also had the center two exhast ports run together. In the flathead crowd it was a well-known modification to run a piece of sheet metal up that center port to divide the sides and increase performance.
There's more to an exhaust system than restriction.
R.
Re: Headers vs HP Manifold [Re: dogdays] #1106835
11/04/11 02:50 PM
11/04/11 02:50 PM
DPelletier Offline
DPelletier  Offline
R.
I am aware of all that, yet my observations are still correct. I presume that you meant to say "increase power by reducing restrictions". Restriction isn't the ONLY part of the equation.....but it is the most important part, esp. when comparing relatively restrictive stock exhaust systems.
Re: Headers vs HP Manifold [Re: DPelletier] #1106836
11/04/11 02:56 PM
11/04/11 02:56 PM
dogdays Offline
dogdays  Offline
Re: Headers vs HP Manifold [Re: dogdays] #1106837
11/04/11 03:04 PM
11/04/11 03:04 PM
DPelletier Offline
DPelletier  Offline
Whatever.
http://www.moparmusclemagazine.com/techarticles/mopp_0106_manifolds_vs_headers/viewall.html
R.
Read it all before.
- 1) Nobody said the headers wont make more power (all other things being equal)
- 2) How much power the headers are likely to add depends on the build and more importantly the cam. There is no way (for example) that headers would make that kind of difference on MY motor because MY cam is designed to make the HP manifolds work.
- 3) that test doesn't take into account the rest of the exhaust system. I've seen a good quality exh system and mufflers make almost .5 seconds difference. How many hp do you suppose that equates to?
......bottom line (as I said) isn't that headers make more power but rather that it has been proven that you can build a HP manifold equipped motor to equal that power level if that's your goal. As I said in my original post, it depends on your perspective.
Re: Headers vs HP Manifold [Re: DPelletier] #1106838
11/04/11 03:15 PM
11/04/11 03:15 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
A manifold engine is like a one legged man in an a** kicking contest.
You can do whatever you want, but having two legs is always better.
Re: Headers vs HP Manifold [Re: RemCharger] #1106839
11/04/11 03:17 PM
11/04/11 03:17 PM
DPelletier Offline
DPelletier  Offline
just don't make the mistake of lining up against some of the manifold equipped cars in F.A.S.T. or it will be your a**
Re: Headers vs HP Manifold [Re: DPelletier] #1106840
11/04/11 03:19 PM
11/04/11 03:19 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Whats even scarier is a fast car with real headers.
Re: Headers vs HP Manifold [Re: RemCharger] #1106841
11/04/11 03:25 PM
11/04/11 03:25 PM
DPelletier Offline
DPelletier  Offline
Yeah, you're right; a 383 with headers is the shiznit!
Re: Headers vs HP Manifold [Re: DPelletier] #1106842
11/04/11 03:31 PM
11/04/11 03:31 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Whats even scarier is a f.a.s.t car with real headers.
Sorry wasn't talking about my car. Reread the quote.
fastest I've gone with my motor is 130 ,, so I'm hardly in the same ranks
Re: Headers vs HP Manifold [Re: RemCharger] #1106843
11/04/11 04:10 PM
11/04/11 04:10 PM
DPelletier Offline
DPelletier  Offline
I did reread your quote; you changed it from "fast" to "f.a.s.t." which changes the meaning......and of course there AREN'T any F.A.S.T. cars with headers......against the rules and all that.
anyway, have a good day.
Re: Headers vs HP Manifold [Re: DPelletier] #1106844
11/04/11 04:22 PM
11/04/11 04:22 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Well I agree, when you have lemons, you make lemonade.
Here's to hoping your day is as good as mine
Re: Headers vs HP Manifold [Re: RemCharger] #1106845
11/04/11 04:47 PM
11/04/11 04:47 PM
DPelletier Offline
DPelletier  Offline
Thanks!
Where in Sask. do you live?; I was just in Regina and Moosejaw for meetings and to visit some friends not too long ago......nice place.
Re: Headers vs HP Manifold [Re: DPelletier] #1106846
11/04/11 05:02 PM
11/04/11 05:02 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
some motors i could not tell seat of pants difference some i could. i put shorty headers on my dodge v-10 truck and i think that was the biggest difference before barely peel out to smoking tires and tearing up the front band
Page 1 of 3 1 2 3
