DANA REAR help #1106769
11/03/11 09:18 PM
11/03/11 09:18 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
Do you need a special tool to put it together??? swapping gears shop says they dont have a/the tool?????
Re: DANA REAR help [Re: zlumlord] #1106770
11/03/11 09:19 PM
11/03/11 09:19 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Spreader tool?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: DANA REAR help [Re: amxautox] #1106771
11/03/11 09:26 PM
11/03/11 09:26 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
directions call for "a tool" no pic??????
Re: DANA REAR help [Re: zlumlord] #1106772
11/03/11 09:30 PM
11/03/11 09:30 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Re: DANA REAR help [Re: Hugh Jorgan] #1106773
11/03/11 10:01 PM
11/03/11 10:01 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
Rears already in the car just swapping gears
Re: DANA REAR help [Re: zlumlord] #1106774
11/03/11 10:51 PM
11/03/11 10:51 PM
What ratio and brand gears are you swapping? Dana 60,(non late model Strange brands) use shims on both ends of the pinion gear and the ring gear carrier or spool. Dana has a factory spec for pinion bearing preload with no seal in place the requires you to take the measument with the pinion gear pointing straight up in the air, not 90 degrees to the floor or Earth You need to take the rear end out of the car to get that measuremnet accurate One other thing is the carriers or spools have at least two different ones depending on the gear ratio, 3xxx carriers work with 3.54,3.73, 4.10 and some brands of 4.30 ratio. The 4xxx cariers are used on the 4.56 and up ratio, you can use two pry bars to remove the carrier but you must maintain the carrier bearing preload as well as the backlash You will need a dial indicator to measure the backlash and a way to measure or insure that you get the pinion depth correct also In other words they're a pain to set up properly, not easy like the 8 3/4 are
Re: DANA REAR help [Re: Cab_Burge] #1106775
11/03/11 10:56 PM
11/03/11 10:56 PM
pa
Z
zlumlord Offline OP
zlumlord  Offline OP
Z
pa
Buddies car at the shop ill send this info over tnx!
Re: DANA REAR help [Re: zlumlord] #1106776
11/04/11 10:03 AM
11/04/11 10:03 AM
LA CA
bron_engines Offline
LA CA
I bit the bullet and bought the ring and pinion installation tool from T&D machine. The same company that makes the rocker arms that we all love. This tool was about 400 bucks but I use it often. As far as a Dana 60 goes, I like to keep the shims behind the pinion bearing and only leave a .010 behind the race on each end of the case. That way it is easy to swap gears if you also keep the bearings on the spool or posi carrier. It takes 1/2 an hour and you are on the road or track.
