rear wheel / axle bearings #1106732
11/03/11 07:43 PM
11/03/11 07:43 PM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
finally putting my 8 3/4 rear back together. question is, don't axle bearings get packed with grease ?
Re: rear wheel / axle bearings [Re: DOUGG] #1106733
11/03/11 07:48 PM
11/03/11 07:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Try to find the thickest bearing grease you can to re-pack them
Gus
64 Plymouth Savoy
Dana 60
Re: rear wheel / axle bearings [Re: fourgearsavoy] #1106734
11/03/11 08:19 PM
11/03/11 08:19 PM
I've always used Kendall blue and MP green in the std tubes & there was something about long fiber types are much better?? No info on that though. I use the needle attachment on a grease gun, works good on installed bearings
