E body trunk torsion rod slider installation #1106627
11/03/11 03:59 PM
11/03/11 03:59 PM
Crook County, ILL
Mastershake340 Offline OP
Crook County, ILL
My trunk lid is moaning and groaning because the nylon slider that goes on the trunk torsion rod and slides against the bottom of the hinge is missing.
I ordered one, but don't see how to install it.
I can't see anyplace to gain enough leverage to pry the rod down away from the hinge to install the slider.
Is there a trick?
My order included 2 sliders, is there a place for a second one on a '71 Challenger, or do you just use one?
Re: E body trunk torsion rod slider installation [Re: Mastershake340] #1106628
11/03/11 04:54 PM
11/03/11 04:54 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Push the rod toward the front of the car and slip on the slider and BTW the 71 Challenger only has 1 rod and slider for the trunk lid.
Re: E body trunk torsion rod slider installation [Re: THESHAKERPROJECT] #1106629
11/03/11 05:59 PM
11/03/11 05:59 PM
Crook County, ILL
Crook County, ILL
Geez, that was easy enough! Thank you Mike!
I have an extra slider if anyone is looking for one.
