how to remove vinyl top trim off back deck /window
#1106376
11/02/11 09:58 PM
11/02/11 09:58 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
Im clear on removing window trim .. but this is the lower or rear trim that holds the vinyl top down.. What is the trick to getting this trim off? its a small rivited piece of flat steel with a tail on it..? what is the best method-tool-procedure i searched but only found window trim techniques..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: how to remove vinyl top trim off back deck /window
[Re: cheapstreetdustr]
#1106377
11/02/11 10:15 PM
11/02/11 10:15 PM
cheapstreetdustr
does this have to be removed from underneath the trunk area? are those the stamped nut type of fasteners? To re-install do i put clips on trim then put trim in place and cap nut it from the trunk? its late i cant see ill have to wait till tommorrow? anyone know....?
#1106378
11/02/11 10:56 PM
11/02/11 10:56 PM
Posts: 221 Detroit Rock City!
silent-H-wheel
Detroit Rock City!
You didn't say what type of vehicle you're working on, but on my '69 Super Bee, the clips were held on to the body by threaded posts with nuts on them, accessible from the inside of the trunk and inside the quarter panel.
Good luck.
John
2019 Jeep Grand Cherokee SRT 2018 Challenger SRT Demon
[Re: silent-H-wheel]
#1106379
11/07/11 12:07 PM
11/07/11 12:07 PM
cheapstreetdustr
70 dart swinger... it had nuts under the deck lid..accessable from the trunk..
now how im gonna clean out the window gutters so the glue will adhere...i have no clue.. looks like more cleaning and cleaning is in order.
what color wax rouge do you use on stainless trim? (how do you spell rooosgh?)
