1970 Cuda 340/ 4 speed transmission mount #1105836
11/02/11 11:28 AM
11/02/11 11:28 AM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
I have a question regarding my transmission mount/crossmember. I'm having a problem determining if I have the wrong trans mount or crossmember. As shown in the photos, the trans mount cushion has pushed itself to one side. I'm wondering if there is a missing retainer, or is this the wrong trans mount completely?.. Or do I have the wrong crossmember installed. Any advise would be appreciated...
Thank you!
Re: 1970 Cuda 340/ 4 speed transmission mount [Re: EF8aar] #1105837
11/02/11 12:10 PM
11/02/11 12:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you need a new mount , that one is damaged.
Re: 1970 Cuda 340/ 4 speed transmission mount [Re: JohnRR] #1105838
11/02/11 12:56 PM
11/02/11 12:56 PM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
Thank you John..
Re: 1970 Cuda 340/ 4 speed transmission mount [Re: JohnRR] #1105839
11/02/11 01:06 PM
11/02/11 01:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
you need a new mount.....and your mount is the correct E body mount/crossmember
Re: 1970 Cuda 340/ 4 speed transmission mount [Re: DAYCLONA] #1105840
11/02/11 02:35 PM
11/02/11 02:35 PM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
Thank you!
