Re: Questions about today's gasoline
[Re: Mike H]
#1105808
11/02/11 02:53 AM
11/02/11 02:53 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Gasoline that has or may have ethanol in it must be labeled on the pump that it contains it. I've seen pumps that say there is no alcohol in the fuel. In my area, all gasoline has ethanol in it. Getting far enough away from the city, I've seen pumps that say they don't have it. I don't know how it is in your area, but you may be in the same boat, that all gas in your area is gasahol. I bought a car last year that I had nothing but problems with the fuel system. The 40 year old tank looked great from the outside, but was full of rust inside. From what I can tell, this car spent most of its time in storage and wasn't driven much. I don't know if it was stored with a full tank or any stabilizer added to the fuel. I had to replace the tank and lines. I have another 40 year old car that I've had 14 years, and in a typical season drive 3-500 miles a year. It is stored 6 months a year. I top the tank and add stabil prior to its winter hibernation, so far no problems with rust in the tank (knock wood!). Again, there is no gas anywhere around here that does not contain alcohol and in 14 years I have not had a problem. My advice would be to top your tank off if you are going to not drive the car for a couple months, and if it is going to sit more than 3 months add stabil or seafoam to the tank.
[Re: Mastershake340]
#1105810
11/02/11 09:05 AM
11/02/11 09:05 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I haul gas. On humid days I have been cautioned against leaving the under ground tank inlet open too long. The alcohol will suck the moisture out of the air. If it gets too much moisture in it? It will create a layer of water, and alcohol towards the bottom. Gas on top. Alcohol is heavier than gas. That gas is usually 84 octane before adding the booze.
Ethanol will rot your rubber fuel lines from the inside out. Buy fuel injection line from the parts store, and buy the FI clamps too.
I would shy away from any plastic filters. The ethanol discolors our sight glasses on our loading heads. It cracks them. It shrinks the rubber seals in our hoses.
Weird thing is my '79 Maxivan wasn't started for 1 1/2 years. E-10 in the plastic tank. It ran fine. I have driven it for over a month. The carb wasn't touched. It is a Mopar Quadrajet. No additives to the tank.
Some areas you can buy "rec" gas. Recreational gas for boats that is alcohol free.
My Husquavarna riding mower owners manual says not to store it with E-10 in the tank over the winter.
When working at Lowes people had lots of issues with the fuel lines in their string trimmers.
I am no authority. Just relating my personal experiences.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#1105811
11/03/11 09:15 AM
11/03/11 09:15 AM
Posts: 277 Palmyra, NY
63stabamatic
Palmyra, NY
I have changed tanks in both cars and run Stabil in everything gas powered. The stock 69 GTX has a little problem with the E10 evaporating when you stop it hot. The other 1963 car has an electric fuel pump but had the rubber hoses around the pump crack prematurely. This site was on another thread this week. There are more stations around me than I realized. http://pure-gas.org/
[Re: 63stabamatic]
#1105812
11/04/11 10:53 AM
11/04/11 10:53 AM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
I personally had bad luck with stabil I use startron . we did a test put fuel in a 5 cups with all the leading drygas or additives let them set on the shelf for one week startron had the least amount of water in it and stayed and smelled like gas all the others where yellow and had water in them in 4 days .we store our harleys our formular 38 foot go fast boat and sleds with startron .I run all my toys almost to mty then a dose of 50/50 gas and startron problem solved .when I store them .I put one bottle in a gallon of gas no more fuel problems .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: Mike H]
#1105814
11/05/11 11:10 PM
11/05/11 11:10 PM
Posts: 101 S.E. WI
RichL1967
S.E. WI
What about Heat? Its supposed to remove water in winter so your gas lines don't freeze. Why not use it for this purpose too. If your in CA I can't believe that you can get non-e10 anywhere. Now Mr.President wants to mandate e-15. Here in Wisconsin (home of the Superbowl Champion Green Bay Packers. ) you can get non-ethanol if your at least about 50 miles from Milwaukee. By that I mean its legal to sell, but most filling stations still have e-10 because that's what the refiners are making, and its easier to get. Usually only the 92 Octane Premium is Non-ethanol. (again only away from Milwaukee) I always use Stabil to store the car for winter but most times I put Heat in at fill up even in the summer.
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
[Re: Mike H]
#1105818
11/07/11 01:29 AM
11/07/11 01:29 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
I have heard any gasoline with ethanol is a bad idea for cars that do not get driven regularly. Ethanol has an affinity for water, which condenses in the tank and lines and rusts them out. I have heard accounts of fuel filters totally clogged with rust. So, what brands of gasoline (if any) don't use ethanol?
Dunno about any US fuel suppliers,but here in Canada,Shell V power (91 octane)contains NO ETHANOL. Says so right on the pump. http://www.shell.ca/home/content/can-en/products_services/on_the_road/fuels/shell_vpower/
Not surprisingly,Sunoco's--or Petro Canada's-Ultra 94 does contain 10% corn whiskey----oops I mean ethanol--in it. http://www.sunoco.ca/default.aspx?ID=2399
For the record,despite the slightly lower octane level,my cars do run better with the Shell V power,no detonation,and get very good MPG.
Ethanol is also know to eat away the leather accelerator pumps in older original carburetors that will cause flat spots and stalling. Been there..got the finger or the horn.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
