Cutters for porting cast iron heads? #1105782
11/02/11 12:58 AM
11/02/11 12:58 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Any good/bad experiences with cutting tools and sanding tools for porting on cast iron heads? What cutters have you found work weel? What styles? Thanks.
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105783
11/02/11 01:05 AM
11/02/11 01:05 AM
Carbide steel burrs, not regular steel Not cheap but they do last a long, long time compared to the standard steel buurs
Re: Cutters for porting cast iron heads? [Re: Cab_Burge] #1105784
11/02/11 01:10 AM
11/02/11 01:10 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
x2 on a carbide burr ... a carbide CUTTER will walk-around too EZ ..
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105785
11/02/11 01:23 AM
11/02/11 01:23 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Mondello sells good cutters. Many different shapes and sizes.
http://www.mondello.com/pages/toc_1.htm
Re: Cutters for porting cast iron heads? [Re: BeEtLeJuIcE !] #1105786
11/02/11 01:33 AM
11/02/11 01:33 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
http://www.ruffstuff.com/pages/carbide.html
I like the oval, shape E burrs. Double cut, 6" long in a variety of sizes. You can get by with just a 3/8", but a 1/2" speeds things up in the long straight stuff, and a 1/4" can make the fine tuning around the guide boss much easier. Those are the three sizes I recommend. Obviously do not start the burr unless it's against some material, do not free spin it (in other words, not have it against material when you're spinning it at speed). You'll want the walls to look straight and as smooth as the burr will get it before you ever touch it with a sanding roll. For cast iron I like 40 grit sanding rolls, but if you spin them too fast they tend to come unraveled. 60 grits hold up better but they don't remove material as fast. I like a combination of 40, 60 and 80 grit. When they start to leave black smears across the port, put a new one on. Trying to use up the whole roll makes for a frustrating port job.
Also, having a good grinder makes the job so much easier. The Suhner grinder (the expensive one) on the website I pasted in is pretty much the Mercedes of all porting grinders. Milwaukee makes one, but your forearms will feel it and they tend to be burr benders as they spin up immediately and only have one speed. Air grinders work, but you don't have as much control unless you get one of those long air grinders, which I have had no experience with.
Grind away!
One more thing! Have a spray bottle of light oil on hand. It'll make the burr last a lot longer. And have your shop vac ready to vacuum out the cuttings. A fan set to the side of the head blowing across it works pretty good to keep the dust out of your lungs and eyes.
Re: Cutters for porting cast iron heads? [Re: dodgeboy11] #1105787
11/02/11 01:55 AM
11/02/11 01:55 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Indeed. That metal dust is some tough stuff to breathe.
I'm curious, why do you not want to spin up the cutter before touching the surface?
Thanks.
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105788
11/02/11 10:26 AM
11/02/11 10:26 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Thanks.
Mask = a good idea. especially on exhaust ports of used heads.
You'll probably still have black snot with a mask , but your lungs will thank you.
I've always done cast iron dry.
Carbide likes coolant , but lubrication , not so much.
A spray bottle of water based machining coolant / lube would be my choice if I used anything.
On aluminum , a shot of silicone ( W.D. 40 or similar ) on the burr periodically really helps cut down on the aluminum in the flutes of your cutter...........they will load up quick even with the more open cutters designed for aluminum. W.D. really helps here.
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105789
11/02/11 11:17 AM
11/02/11 11:17 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Thanks.
On a small shank cutter it's really not that big of a deal but when you get to a long shank to get down into the runners if you let it free spin it can and will bend over and "helicopter" right at the collet.
To much unsupported mass spinning at those speeds gets out of balance real quick. DAMHIK
Re: Cutters for porting cast iron heads? [Re: WILD BILL] #1105790
11/02/11 12:15 PM
11/02/11 12:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Done it myself ... doooh ...
Re: Cutters for porting cast iron heads? [Re: JohnRR] #1105791
11/02/11 12:37 PM
11/02/11 12:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 2 12" long burrs and I made up a holder with
a bearing in it to hold the burr near the end... takes
2 hands to use the 12" cutters... I use to use a leather
glove to hold on to the shaft as close as possible
but it would get warm/hot on the glove
Re: Cutters for porting cast iron heads? [Re: MR_P_BODY] #1105792
11/02/11 02:22 PM
11/02/11 02:22 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I don't like porting heads, but I put a piece of 3/8" fuel hose over the shank of my long carbide burr. I found it useful for using it as a guide to control the cutting end.
If I port another set of heads, I'll try using my mill to do most of the work. I don't know how that will work out, but if I can figure out how to program a port, I wouldn't be doing the hand work as much.
Floyd Lippencott IV
Re: Cutters for porting cast iron heads? [Re: WILD BILL] #1105793
11/02/11 09:19 PM
11/02/11 09:19 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I wouldn't have thought a cutter on a mere 6" shaft would bend like that, but I can believe it could happen.
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105794
11/04/11 11:02 AM
11/04/11 11:02 AM
Illinois
SteveA Offline
SteveA  Offline
Illinois
Can anyone recommend a decent electric die grinder ? I won't use it much, just occasionally to clean up the ports, gasket match, or debur a block or two.
Steve
Re: Cutters for porting cast iron heads? [Re: SteveA] #1105795
11/04/11 01:21 PM
11/04/11 01:21 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I used to use the Craftsman die grinder - back then it was the only reasonably priced one out there. Problem was it got too hot to handle after short use. Also, get one with variable speed ... you don't want to be doing everything at 25,000 rpm !! For minimal use maybe check out Harbor Freight !!
Re: Cutters for porting cast iron heads? [Re: SteveA] #1105796
11/05/11 01:00 AM
11/05/11 01:00 AM
Don't buy the newer electric Craftsman or Makita , the chuck sucks, they will hurt you. I like and use the little Harbor Frieght brand Central Pnumatic die grinders with the 1/4 chucks
Re: Cutters for porting cast iron heads? [Re: Cab_Burge] #1105797
11/05/11 01:28 AM
11/05/11 01:28 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
Re: Cutters for porting cast iron heads? [Re: dodgeboy11] #1105798
11/05/11 01:46 AM
11/05/11 01:46 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
one of the best things on that site is one of the cheapest, a split mandrel. get a roll of 60 grit cloth and it will save you a ton of cash from all of the cartridge rolls that you won't need.
Re: Cutters for porting cast iron heads? [Re: GTXX] #1105799
11/05/11 02:16 AM
11/05/11 02:16 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I suppose that if I have to spend $100 on cutters, I might as well send the heads to Muscle Motors and let them port and rebuild them?
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105800
11/05/11 01:34 PM
11/05/11 01:34 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Paying a pro is well worth the $$$ in my opinion.
I have done my own and had decent results by not going overboard.
It is hard to quantify because I also did some suspension changes.....it was an over the winter project that netted .15 on the E.T. , but what helped most is hard to say.
It picked up 3-4 m.p.h. in the eighth though , and that indicated motor over suspension I think.
I have an old Makita electric ( Japan ) and it is a war horse , but as production went over to the Red Menace , quality went south.
Same for Milwaukee , and probably every other tool maker.
If you are going to use it , buy quality.
If it is a one shot , buy junk.
Re: Cutters for porting cast iron heads? [Re: lahatte] #1105801
11/06/11 02:15 AM
11/06/11 02:15 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Typically it's the sanding roll mandrel that'll bend. The rolls aren't exactly balanced well and if it comes out of the port at speed that puppy will go at a 90 degree angle right away. And if your face is anywhere near the port at the time...
