Will a ramcharger breather fit? #1105698
11/01/11 11:53 PM
11/01/11 11:53 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
I have a 70 Superbee with a 440 and an RPM Ebrock intake. I want to run a Holly type carb with the ramcharger fresh air box and air cleaner setup, but don't know if it will work. I thought only a Carter type carb would work but don't know for sure. Anyone have any experience with this?
Thanks!
Re: Will a ramcharger breather fit? [Re: slowpoke] #1105699
11/02/11 09:26 AM
11/02/11 09:26 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I had a '70 383 Bee with the Rmacharger induction. N96. I installed a Holley Street Dominater intake. I had to cut the base and weld a flat plate to it. Then cut out the carb hole.
You don't have much clearance. The Holley isn't very tall. Especially compared to the RPM. BTW I ran an AFB replacing the factory Holley.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Will a ramcharger breather fit? [Re: slowpoke] #1105700
11/02/11 09:41 AM
11/02/11 09:41 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Thanks!
it won't fit. the only two intake/carb combos that fit with factory parts are stock 4bbl or 6bbl.
Re: Will a ramcharger breather fit? [Re: lewtot184] #1105701
11/02/11 10:14 AM
11/02/11 10:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The air cleaner will fit on the holley and clear if it were on a stock height intake. On the RPM , NO WAY , you'll have to modify the baseplate .
Re: Will a ramcharger breather fit? [Re: JohnRR] #1105702
11/10/11 06:34 PM
11/10/11 06:34 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Sorry I've been away for quite a while.
Thanks everyone for the info. Didn't think it would work.
