95 model 360 magnum
#1105134
11/01/11 12:40 PM
11/01/11 12:40 PM
Posts: 9 Carriere, MS
Flucus
Carriere, MS
can anybody tell me for sure if the new magnum motors have a right and left head gaskets? i have been having overheating problems on a new rebuild. I have changed everthing that pertains to cooling with brand new parts including a high voleum water pump.
64 Barracuda
70 Duster
70 Dart
79 Warlock Truck
92 Dodge 150
05 Magnum
Re: 95 model 360 magnum
[Re: Flucus]
#1105135
11/01/11 01:38 PM
11/01/11 01:38 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Definately not left and right hand but most gaskets have a front and back, the differance is the coolant holes, the front hole in the deck is blocked to force coolant to the rear of the motor, if the rear hole is blocked it will only cool the front cylinders.
[Re: HotRodDave]
#1105136
11/01/11 02:22 PM
11/01/11 02:22 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Makes me wonder if this isnt the reason behind why a lot of people chase their tails with the cooling problems they have.
[Re: POS Dakota]
#1105137
11/01/11 02:55 PM
11/01/11 02:55 PM
Flucus
Carriere, MS
thanks im gonna test the heat comming off the headers to check and see if there are any difference
64 Barracuda
70 Duster
70 Dart
79 Warlock Truck
92 Dodge 150
05 Magnum
[Re: HotRodDave]
#1105139
11/01/11 04:44 PM
11/01/11 04:44 PM
Flucus
Carriere, MS
i have taken the top end down 3 different times had the heads checked twice and the bought new ones and the last time i realy focused on the head gaskets so im gonna test the heat on the block and not the headers to see if i screwed up somewhere, thanks for the info
64 Barracuda
70 Duster
70 Dart
79 Warlock Truck
92 Dodge 150
05 Magnum
