67 Coronet R/T front parking lights???? #1104901
10/31/11 09:17 PM
10/31/11 09:17 PM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
Tring to get things working on this car.. Parking lights go out when the headlights are turned on. Also all lights work but right front directional. Flashers work so its not the bulb. What to check???
Re: 67 Coronet R/T front parking lights???? [Re: Russ_Davis] #1104902
10/31/11 09:22 PM
10/31/11 09:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
They don't stay on when headlights are on. Ainnasposed tuh.
Re: 67 Coronet R/T front parking lights???? [Re: Russ_Davis] #1104903
10/31/11 09:26 PM
10/31/11 09:26 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Do you have a factory service manual? It`s all in there on hows it`s wired up. The front parking lights are working exactly like they should be. Turn the headlight switch on to the parking light position and the parking lights will be on, turn on the headlights and the parking lights will go off. My 67 GTX is the same way and my 68 Charger was the same way.
Nobody gets in to see the wizard!
Ain`t no way!
Ain`t no how!
