Spreadsheet Tool for Calculating Compression, etc.
#1104430
10/31/11 01:24 AM
10/31/11 01:24 AM
Posts: 392 Mississippi
lahatte
Mississippi
I had posted this (see attachement) in another thread, but I thought people might find it useful. It gives you compression ratios, both static and dynamic (based on intake opening angle), and some other useful info. If you find it useful, great, If you find it to be crap, well, let me know.
Re: Spreadsheet Tool for Calculating Compression, etc.
[Re: lahatte]
#1104431
10/31/11 11:44 AM
10/31/11 11:44 AM
Posts: 4,209 New York
polyspheric
New York
Very nice work, thanks. If you will permit, an observation? 1.4 is a bit optimistic for the heat expansion ratio. It's always going to be slightly lower depending on heat lost from the chamber and cylinder walls which as you can imagine varies quite a bit with water temp, exposed area, material, etc.
Boffin Emeritus
[Re: mr_340]
#1104435
11/01/11 07:53 AM
11/01/11 07:53 AM
Posts: 3,453 Dandridge TN
Dabee
Dandridge TN
I couldn't download it for some reason. If the 1.4 number is the ratio of specific heats (as in the Otto cycle efficiency), then I remember my combustion engines professor at UT telling us sometimes using 1.3 is a better number to use. I think the 1.4 number is for pure air instead of the air/fuel mixture.
My Norton software says the file is corrupt.
[Re: lahatte]
#1104436
11/01/11 04:51 PM
11/01/11 04:51 PM
Posts: 16,928 NC
440Jim
NC
...dynamic (based on intake opening angle
Thanks for sharing. The spreadsheet needs intake valve closing for dynamic calc. What cam event should we use? 0.050", 0.020", actual lash (ex/0.022") ?
[Re: 440Jim]
#1104438
11/01/11 08:07 PM
11/01/11 08:07 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Although I cannot open the attachment, I struggle with this same question on all of the Dynamic CR formulae that I've looked at as they are not clear. Is it actual seat timing?, or at 0.004" or 0.005" or 0.006" like hydraulic advertised?, or 0.050" @ the lifter?, or valve?
I measure and record all of these (and more) at the lifter, the valve, and at different lash settings. The few times I've plugged the values in to some DCR formulae, I question the results relative to the rule of thumb on what is acceptable for pump gas.
[Re: 440Jim]
#1104440
11/01/11 08:34 PM
11/01/11 08:34 PM
lahatte
Mississippi
Regarding the intake valve closing, it is based on the number specified by the manufacturer as the ABDC closing, as in this example... http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=708&sb=2Because compression can't truely begin until the intake valve is closed, I assume the number should refer to the actual degrees where the valve shuts, or very close to it. A cam spec expert might want to chime in on the intended meaning of that number in the specifications.
[Re: lahatte]
#1104441
11/01/11 08:55 PM
11/01/11 08:55 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
Strange the attachment is just an Excel 2003 file that was zipped so I could attach it. I'll try again here...
Try just attaching the excel file...don't zip it and it it will probably work.
[Re: lahatte]
#1104442
11/01/11 09:08 PM
11/01/11 09:08 PM
BSB67
Prospect, PA
i.e. 0.006" measured at the lifter.
