Cam,lifter & rocker noise? #1104404
10/31/11 12:49 AM
10/31/11 12:49 AM
Windsor ,Ca.
K
Keith Richards Offline OP
K
Windsor ,Ca.
I have done searches and read many threads on this subject and I have noise which too me seems a bit excessive. My noise comes in about 2000 rpm and runs through 2500 rpm and then is gone again. It sounds like the rockers are not receiving oil in this rpm range. The car is my '72 road runner it has it's numbers matching 400 block in it with a 440 rotating assembly and is 451" 's, car also has a 4 speed so I easily get in this rpm range between shifts. The cam/lifter kit I put in is a Lunati voo doo #60303 with adv duration of 268 int./276 exh. and 0.494 int./0.513 exh.lift. The motor has the Edelbrock 88cc heads with the Edelbrock springs that are supposed to be good for .600 lift. I will say this is the best cam I have had in this motor (I have had a Comp hyd and a MP solid that worked terrible with the 4 speed)as it has awesome torque and pulls great with the 4 speed and 3.55 rear gears.
Somebody told me to switch in a set of the standard Comp #822 lifters would get rid of this as the Lunati lifters are staying pumped up in this range and making noise?
Any comments? Is this similar noise as some of you are experiencing?
Re: Cam,lifter & rocker noise? [Re: Keith Richards] #1104405
10/31/11 12:58 AM
10/31/11 12:58 AM
Any comments?
What's your preload?
Re: Cam,lifter & rocker noise? [Re: RapidRobert] #1104406
10/31/11 01:02 AM
10/31/11 01:02 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
I have played around from 3/4 turn, 1/2 turn and right now a quarter turn, when I initially set the 1/2 turn I had the intake off so I could be absolutely sure the cup was up against the lock. It makes the same noise and in the same rpm range in all of the above.
Re: Cam,lifter & rocker noise? [Re: Keith Richards] #1104407
10/31/11 01:12 AM
10/31/11 01:12 AM
Yeah this is strange that it only acts up in that narrow rpm range. I wouldn't think it'd have a severe drop in psi just in that range. Does it sound like classic lifter clattering from low psi or a different arm/shaft noise or can you tell
Re: Cam,lifter & rocker noise? [Re: RapidRobert] #1104408
10/31/11 01:40 AM
10/31/11 01:40 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
Noise sounds like rocker arm clatter, oil pressure stays strong and if you hold it in that range for any length of time the noise stays the same. The oil looks clean as does the oil laying in the heads when the covers are off. I have tried different oils 20-50 originally and recently changed to 10-30 to see if that would change the noise, which it didn't. Oil pressure is high and this motor has no more then 500 miles on it since a complete rebuild, may go to a hydraulic roller if I can't figure this out, hate the thought of that expense this winter but would like to try and keep this cam if I can get it quieted down since it works so well, thing sounds like a diesel in that bad range.
Re: Cam,lifter & rocker noise? [Re: Keith Richards] #1104409
10/31/11 02:19 AM
10/31/11 02:19 AM
I wonder if it could be as simple as a bad lifter(s) and breaking in a new set would be the ans? If so it'd sure be the cheapest way to go. Holler how it turns out & good luck
Re: Cam,lifter & rocker noise? [Re: RapidRobert] #1104410
10/31/11 07:36 AM
10/31/11 07:36 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
What kind of rockers are you running?
Re: Cam,lifter & rocker noise? [Re: 6PACMAC] #1104411
10/31/11 07:59 AM
10/31/11 07:59 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Due to ramp design on some of the new cam profiles there seems to be some 'noise' or periods of noise. If it runs good leave it alone.
Re: Cam,lifter & rocker noise? [Re: MoparforLife] #1104412
10/31/11 11:00 AM
10/31/11 11:00 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..seems fast rate cams can be noisy
Re: Cam,lifter & rocker noise? [Re: MoparforLife] #1104413
10/31/11 11:30 AM
10/31/11 11:30 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Every Comp cam or MP cam I've ever used had that "clatter" in that exact RPM range.
Personally, you are NOT going to get rid of it. Like said...it runs fine & you know the lifters are preloaded.....Drive it!!!!
Re: Cam,lifter & rocker noise? [Re: superwrench] #1104414
10/31/11 11:35 AM
10/31/11 11:35 AM
That dont sound good but as double R would say ding ding ding we (do) have a winna. (Just me I'd have to go with something else) but at least now we know what's up
Re: Cam,lifter & rocker noise? [Re: RapidRobert] #1104415
10/31/11 11:44 AM
10/31/11 11:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Some years back I had the MP .484 cam in a 340 Dart and it had the same noise. Never could find anything wrong and it ran great. Ron
Re: Cam,lifter & rocker noise? [Re: 383man] #1104416
10/31/11 01:53 PM
10/31/11 01:53 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I have exactly the same problem with a Crane in mine. It doesn't seem to noticably affect performance, just very annoying. Switched rockers from H.S. to Isky Iron. No difference. Tried all different preloads. No difference. Tried different length pushrods. No difference. Looked to see if rockers were hitting valve covers. Nope. Thought maybe what I really had was a header leak so I changed to Remflex gaskets. No difference. I give up. I'll put a solid in it before I try anything else. Then it will make less noise and have more power. Perfect.
Re: Cam,lifter & rocker noise? [Re: GomangoCuda] #1104417
10/31/11 02:22 PM
10/31/11 02:22 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Keith , how much valve spring pressure you running? Anything over 130# on a hydralic cam is excessive and can cause that.
Re: Cam,lifter & rocker noise? [Re: GomangoCuda] #1104418
10/31/11 03:03 PM
10/31/11 03:03 PM
Upper Midwest
Upper Midwest
Yes and no. In order to make more power you will need to go bigger with the solid cam. IE: a MP 528 is actually a lesser/milder cam that the 509. Have to take the lash numbers off the solid cam to get effective numbers. Been down that road.
Re: Cam,lifter & rocker noise? [Re: MoparforLife] #1104419
10/31/11 03:49 PM
10/31/11 03:49 PM
GomangoCuda Offline
GomangoCuda  Offline
Already knew that. Thanks
Re: Cam,lifter & rocker noise? [Re: GomangoCuda] #1104420
10/31/11 04:12 PM
10/31/11 04:12 PM
Norway
General 68 Offline
General 68  Offline
Norway
The 60303 in my 440 has been clattering along for four summers without any issues. Noisy but pulls strong.
Re: Cam,lifter & rocker noise? [Re: General 68] #1104421
10/31/11 11:57 PM
10/31/11 11:57 PM
mi
E
ERAT340 Offline
ERAT340  Offline
E
mi
Guys! Its spark knock. This sound fooled me when I was a younger man. Try ta back off your timing, see if it changes.
Re: Cam,lifter & rocker noise? [Re: ERAT340] #1104422
11/01/11 10:35 AM
11/01/11 10:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That sounds like something to check .
What is intial timing , total timing , all in by , and do you have your vac. adv. connected?
What pistons are you running with those open chamber ebrocks , what is your compression ratio ?
And someone asked , what rockers ?
Re: Cam,lifter & rocker noise? [Re: JohnRR] #1104423
11/01/11 11:08 AM
11/01/11 11:08 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
If it does it when the car is not in gear, it is most likely not detonation as there is not enuf to load on the engine to generate the heat required. If you have a vacuum advance disconnect it and see if it then goes away.
Steve
