how to get 3 temp sensors in a bb water pump housing? #110430
08/26/08 12:19 AM
08/26/08 12:19 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
How do I get 3 water temperature sensors into a bb water pump housing? I have the stock 1/8"npt sensor, a self drilled/tapped efi water temp sensor located on the heater hose side. I can eliminate the stock sensor but i don't know if there is enough meat there to drill and tap out to 1/2npt, has anyone ever done that? any other ideas? I was thinking about using a t in the heater hose (yeas, I'd like heat in the winter) but I was concerned about the temp not being accurate, which hose is the feed off of the water pump? thanks
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: how to get 3 temp sensors in a bb water pump housing? [Re: whiplash] #110431
08/26/08 02:26 AM
08/26/08 02:26 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
If you used the CSR water neck, you could weld an aluminum bung on top for one I think.
I have the Meziere one on my 383 but its not flat on top.
Ride eternal, shiny and chrome
Re: how to get 3 temp sensors in a bb water pump housing? [Re: DirectSubjection] #110432
08/26/08 09:04 AM
08/26/08 09:04 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
But then the temp will be inaccurate until the stat opens fully?
If I have to do that, I'd rather tap into the heater core inlet fitting off the water pump with a T
Re: how to get 3 temp sensors in a bb water pump housing? [Re: whiplash] #110433
08/26/08 09:52 AM
08/26/08 09:52 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
How about adding a spacer under the t-stat with a couple sensor ports? Not sure how much that one costs, Weiand makes one that they sell for about $70. Plenty spendy, but not high tech... Wink, wink...
Clair
Re: how to get 3 temp sensors in a bb water pump housin [Re: whiplash] #110434
08/26/08 10:06 AM
08/26/08 10:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what water pump housing do you have , iron or alum ???
Re: how to get 3 temp sensors in a bb water pump housin [Re: JohnRR] #110435
08/26/08 10:21 AM
08/26/08 10:21 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
john,
Its the iron one. I looked at the AL one and same issue, not enough ports. what are your thoughts?
The t-stat extension sounds interesting, it is under the stat so I should get a pretty good idea of block temp, there should be enough turbulence there to allow an accurate reading. Gonna go look for it
Re: how to get 3 temp sensors in a bb water pump housin [Re: whiplash] #110436
08/26/08 10:44 AM
08/26/08 10:44 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
one more question will the stuff for SBC and BBC fit the BBM water pump outlet and t stat?
I've found quite a few for SB/BBC with 2-3/8"NPT ports for around $40.
Re: how to get 3 temp sensors in a bb water pump housin [Re: whiplash] #110437
08/26/08 11:10 AM
08/26/08 11:10 AM
Here
Here
Yeah - that's a much better idea than my suggestion.
I have a BBC water neck on my 383, just used a Chevy T-stat with it.
I don't know if you could use a Mopar water neck on that BBC piece though, I'm sure someone will know though.
Re: how to get 3 temp sensors in a bb water pump housin [Re: whiplash] #110438
08/26/08 11:52 AM
08/26/08 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you could add the ports on an Alum. one, I think , I'll have to look at the MP one I have at home later and compare it to an iron one though I have added the 1/8" port to an alum. one already that it didn't have.
Your issue is having a heater , if you didn't would be a piece of cake.
Re: how to get 3 temp sensors in a bb water pump housing? [Re: whiplash] #110439
08/26/08 10:00 PM
08/26/08 10:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I looked at the housings , should be easy, you could couple probably do it to the iron one you have.
The alum MP unit has the heater hose connections plus a 1/2" pipe towards the thermostat just like the iron ones do , then you can add in the 1/8 in the stock location , if you go alum . The alum also has an 1/8 tapped port on the drivers side leg that runs to the underside of the thermostat , it's offset towards the block. You could hit that one with an endmill to move the centerline over for the 1/2 npt port , or you could just drill the 1/2 npt port in your current iron one on that side that doesn't have any .
Re: how to get 3 temp sensors in a bb water pump housing? [Re: whiplash] #110440
08/26/08 10:10 PM
08/26/08 10:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You can also drill and tap the block just in front of the head.
