Duster rallye dash gas gauge..... #1104234
10/30/11 05:26 PM
10/30/11 05:26 PM
owt west
Thread Ender1 Offline OP
owt west
Im just completing my 71 Duster project to find gas gauge, temp and oil pressure do not work.
It appears that there is a voltage limiter inside of the gas gauge that fails often.
Does any one have a for sure way of bench testing the gas gauge and the voltage limiter part.
It is NOT easy at all R&R on those rallye clusters so any
Re: Duster rallye dash gas gauge..... [Re: Thread Ender1] #1104235
10/31/11 12:13 PM
10/31/11 12:13 PM
cali
68mannix Offline
68mannix  Offline
cali
im interested to,be a good thing to know.
Re: Duster rallye dash gas gauge..... [Re: 68mannix] #1104236
10/31/11 06:31 PM
10/31/11 06:31 PM
okla.
O
okie Offline
okie  Offline
O
okla.
You can check the oil and temp. gauge with a 9 volt battery, but just put it on long enough to see if they move. I think you can put a ground on the dash frame and turn it on hooked up and see if you get a flashing test lite on it. I may have a good gauge if you need one. Ronnie
Re: Duster rallye dash gas gauge..... [Re: okie] #1104237
10/31/11 06:32 PM
10/31/11 06:32 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Put the test lite on your gas gauge.
