1987 Jeep Wrangler question. #1104136
10/30/11 11:18 AM
10/30/11 11:18 AM
New York
jagrunt551 Offline OP
New York
Looking at a 1987 Wrangler that the seller says neeeds a clutch slave cylinder. He says that someone tried to fix it. They put Hydralic oil in instead of Hydralic fluid. Can the system be drained and flushed or do you need to just replace the slave cylinder? Thanks
Re: 1987 Jeep Wrangler question. [Re: jagrunt551] #1104137
10/30/11 11:57 AM
10/30/11 11:57 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
most likely the slave cyl is leaking,They were probably hoping the thicker fluid would help/slow it down.Very common on the 4 cyl engines to have leaky slaves.I think it's because of all the shifting you need to do with the 4 banger.Expect to remove the trans and replace it.
Re: 1987 Jeep Wrangler question. [Re: moretoys] #1104138
10/30/11 02:57 PM
10/30/11 02:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've got an 88 Wrangler. These jeeps in this year did not run an external slave cylinder. They ran a hydraulic throw out bearing, so you have to pull the trans to replace it. You can try draining the oil and flushing it out with brake fluid to see if it helps, but if it's leaking, the trans has to be dropped.
