My 416 Stoker motor. #1104126
10/30/11 10:46 AM
10/30/11 10:46 AM
Indiana
SB Dakota Offline OP
Indiana
Well i would like to thank mike @ mrl for all his help in helping me put together a very sweet 416 stoker motor.
THANK YOU MIKE.............
And to Gray @ Zimmerman bros motorsports for all the machine shop work.
Now here is the good stuff
70 340 block .030 over
Align hone mains
burnish lifter bore
and all the good stuff the machine shop does.
Scat I beam rods
Scat 9000 340 4" crank
KB 25cc dish pistons 340/360w/4.00" stroke w/ rings
Balance rotating assembly
SBM double roller timing set
deck the head surfsce ........ RHS X Indy heads
1.92/1.1.625 valves
Lunati voodoo cam.242 / 252 or .533 /.552
some small port work done
Super Victor intake
Biggs stage 5 750 DB
Hooker comp headers
PRM Stainlee steel rocker kit 1.5 ratio
One more time thanks mike for all your
Larry Anderson 87 Dodge Dakota 416 Stroker 71 Dodge Dart http://i58.photobucket.com/albums/g254/rules371/88888888888-1.jpg
Re: My 416 Stoker motor. [Re: SB Dakota] #1104127
10/30/11 10:51 AM
10/30/11 10:51 AM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Should run sweet, let us know how it does.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: My 416 Stoker motor. [Re: SB Dakota] #1104128
10/31/11 01:01 PM
10/31/11 01:01 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Whats this TQ monster going in? HP? TQ?
Sounds like a good street combo!
Snap your neck, mega G-force launch, is all I want!
Re: My 416 Stoker motor. [Re: SB Dakota] #1104129
10/31/11 03:25 PM
10/31/11 03:25 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Wow! That is almost the same as my combo, only I run Edelbrock heads and some other minor differences. Should be a GREAT street/strip combo. Mine runs 10.8's @ through the muffs in my Barracuda.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
