No power steering while turning left. '04 Jeep GC #1103998
10/30/11 12:16 AM
10/30/11 12:16 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Loud hissing and I loose all power steering when turning left only. Turning right is not a problem. This is a '04 Jeep Grand Cherokee with the 4.7. Power steering pump is not low on fluid.
New to me, what could cause this???
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1103999
10/30/11 12:20 AM
10/30/11 12:20 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Steering box.. Problem is in the control valve section...
Re: No power steering while turning left. '04 Jeep GC [Re: 1_WILD_RT] #1104000
10/30/11 12:40 AM
10/30/11 12:40 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Is replacing the steering box the only fix?
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104001
10/30/11 12:45 AM
10/30/11 12:45 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your adventurous & can find a seal kit it might be worth taking a look... Probably a sticky valve or a damaged sealing ring...
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104002
10/30/11 12:46 AM
10/30/11 12:46 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I would look and see if the steering shock is bent.
Re: No power steering while turning left. '04 Jeep GC [Re: 1_WILD_RT] #1104003
10/30/11 12:48 AM
10/30/11 12:48 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the help.
Re: No power steering while turning left. '04 Jeep GC [Re: Todd] #1104004
10/30/11 12:49 AM
10/30/11 12:49 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Shouldn't be this (wife's daily driver) but I will check.
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104005
10/30/11 12:55 AM
10/30/11 12:55 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Check and see if it stops assisting in the same spot.
Re: No power steering while turning left. '04 Jeep GC [Re: Todd] #1104006
10/30/11 02:35 AM
10/30/11 02:35 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I don't follow...
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104007
10/30/11 02:47 AM
10/30/11 02:47 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
His suggestion points to a binding situation due to bent parts... And it's certainly worth checking out.. But your comment about the hissing sounds like fluid bypassing...
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104008
10/30/11 09:02 AM
10/30/11 09:02 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I don't follow...
If you turn all the way to the right then try to turn back to the left does it quit right there or can you turn the wheel some before it stops assisting? Also try and raise the engine rpm up to about 2k and see if it changes. If so the pump could be the culprit. Havent seen to many metering valves in those gear boxes go bad unless they have been crashed.
Re: No power steering while turning left. '04 Jeep GC [Re: Todd] #1104009
10/30/11 01:16 PM
10/30/11 01:16 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I don't follow...
It won't turn left at any index in the steering. I put it in neutral and raised the rpm to 2-3K and no change.
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104010
10/30/11 01:47 PM
10/30/11 01:47 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I don't follow...
If everthing else has checked out ok, the next thing to look at as some of the other posters said was the metering valve in the gear box.
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104011
11/03/11 01:43 AM
11/03/11 01:43 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
What is this cast piece pictured below? There are two high pressure and one lower pressure lines attached to this piece that go to the power steering pump and gear box.
Could this be part of my problem?
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104012
11/03/11 01:48 AM
11/03/11 01:48 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Are you sitting down? That is a hydraulic fan motor....
Re: No power steering while turning left. '04 Jeep GC [Re: VITC_GTX] #1104013
11/03/11 02:01 AM
11/03/11 02:01 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Yes, don't waste your time trying to fix the box.
