Re: No power steering while turning left. '04 Jeep GC
[Re: VITC_GTX]
#1103999
10/30/11 12:20 AM
10/30/11 12:20 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Steering box.. Problem is in the control valve section...
[Re: VITC_GTX]
#1104001
10/30/11 12:45 AM
10/30/11 12:45 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
If your adventurous & can find a seal kit it might be worth taking a look... Probably a sticky valve or a damaged sealing ring...
[Re: Todd]
#1104004
10/30/11 12:49 AM
10/30/11 12:49 AM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
I would look and see if the steering shock is bent.
Shouldn't be this (wife's daily driver) but I will check.
[Re: VITC_GTX]
#1104007
10/30/11 02:47 AM
10/30/11 02:47 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
His suggestion points to a binding situation due to bent parts... And it's certainly worth checking out.. But your comment about the hissing sounds like fluid bypassing...
[Re: Todd]
#1104009
10/30/11 01:16 PM
10/30/11 01:16 PM
VITC_GTX
Check and see if it stops assisting in the same spot.
I don't follow...
If you turn all the way to the right then try to turn back to the left does it quit right there or can you turn the wheel some before it stops assisting? Also try and raise the engine rpm up to about 2k and see if it changes. If so the pump could be the culprit. Havent seen to many metering valves in those gear boxes go bad unless they have been crashed.
It won't turn left at any index in the steering. I put it in neutral and raised the rpm to 2-3K and no change.
[Re: VITC_GTX]
#1104010
10/30/11 01:47 PM
10/30/11 01:47 PM
Posts: 1,377 Ohio
Todd
Ohio
I don't follow...
If everthing else has checked out ok, the next thing to look at as some of the other posters said was the metering valve in the gear box.
[Re: VITC_GTX]
#1104011
11/03/11 01:43 AM
11/03/11 01:43 AM
VITC_GTX
What is this cast piece pictured below? There are two high pressure and one lower pressure lines attached to this piece that go to the power steering pump and gear box.
Could this be part of my problem?
[Re: VITC_GTX]
#1104013
11/03/11 02:01 AM
11/03/11 02:01 AM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Is replacing the steering box the only fix?
Yes, don't waste your time trying to fix the box.
