I have a 70 Cuda with factory front disk brakes. I looked under the car last week and noticed that there was brake fluid puddled on the floor next to the driver side tire (engine compartment side). It turns out it is leaking where the hose connection goes into the caliber housing. I tried tightening it but it would not turn anymore so it seems that it is as tight as it will get. I took the car out for short drive and parked it. About an hour later I came out and looked under the car and their was brake fluid running down the back of the caliper housing again.
The front brake hoses on the car where replaced (not by me)about 9 years ago and appear to be in good shape. The other side had the same problem about a year ago and I just went out and tightened it a little and that seemed to fix the problem.
So I'm wondering where to go at this point. Should I loosen the connection and try re-tightening it or am I going to have to replace the brake hose?
